What oil to use? ford 302 - Ford Truck Enthusiasts Forums
Old 07-31-2009, 12:39 PM
oldblue89 oldblue89 is offline
oldblue89 is starting off with a positive reputation.
What is the recommended oil to use in the summer and winter in my 1989 f150 with a 302?
Old 07-31-2009, 02:36 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Regular old 10w30 dead dinosaur is all the motor really needs.
Old 07-31-2009, 08:11 PM
Good, that's what I've been using. Same oil for the summer and winter? I live in Northern Virginia, in the twenties and thirties fahrenheit in the winter and eighty to ninety degrees fahrenheit in the summer.
Thanks
Old 07-31-2009, 10:09 PM
Conanski's Avatar
5w30 is also acceptable according to my manual though in my experience you may get more mechanical noise on higher milage engines.
Old 08-04-2009, 12:30 PM
fraso fraso is offline
fraso is starting off with a positive reputation.
I'd also consider using a 10W-30 Heavy Duty Engine Oil (HDEO) rather than a Starburst oil in your engine.
Heavy Duty Engine Oils
Old 08-04-2009, 02:38 PM
Neptoess Neptoess is offline
Neptoess is starting off with a positive reputation.
10w30 in the summer, 5w30 in the winter. Or 5w30 year round if you run a decent oil. Conanski is right conventional oil is all the engine needs but I hopped on that valvoline 300k mile engine guarantee, which requires me to run their full synthetic. I've had no problems with the SynPower 5w30, except the price of 6 qt full synthetic oil changes every 3k
Old 08-04-2009, 03:08 PM
truckrider814's Avatar
truckrider814 truckrider814 is offline
truckrider814 is gaining momentum as a positive member of FTE.
I actually live in Northern Va too and i run 10W30 just fine all year around. My mileage just turned 190,000 no weird noises when it turns cold or hot.
My .02 cents
Kyle
Old 08-04-2009, 06:03 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Does Valvoline require you to change the oil that often to qualify for their warranty? 3k mile oil changes on synthetic is extreme overkill. I would feel safe doubling the interval to 6k miles, even with conventional oil.
Old 08-04-2009, 08:52 PM
they have a 1k grace period. so technically you can do it every 4k miles. amsoils recommended intervals on their oil(which is like the best) is 15k, but they dont have the engine guarantee haha
Old 08-04-2009, 10:07 PM
It seems to me that Valvoline's engine guarantee is written to protect them rather than their customers. Any API SM oil should offer excellent protection and can easily go 5000-6000 miles between oil changes. Many people running synthetics run a lot more than 6,000 miles between oil changes based on UOA.
See BITOG: Valvoline's Oil Warranty
HDEOs (CI-4/SL, CJ-4/SM) offer higher levels anti-wear additives and detergents than Starburst Oils and are excellent choices for older engines.
ACCCC Engine Oil Article
Old 08-04-2009, 10:18 PM
bren_tx bren_tx is offline
bren_tx is starting off with a positive reputation.
i use mobile 1 10w30 year round in my 302 and change it every 5k. with 360,000 miles, i can pull the valve covers and eat off of them they are so clean
Old 08-04-2009, 11:37 PM
yeah even if it CAN last that long, their engine guarantee keeps the oil at the point where it doesnt even need changed. But i figure if i happen to throw a piston or get a ****ed up valve it's on them since they warrant anything the oil touches unless it fails because of something else, but 302s are known for reliability even on dirt cheap conventional oil so 300k on full synth starting at 39k miles with 3k intervals should last me a while. I already know the truck will rust away before the powertrain goes though
Old 08-04-2009, 11:48 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
Quote:
I haven't checked the owners manual on my 91 F-150 to see what it says, but according to my Chilton service manual, oil and filter changes are recommended every 6 months or 6k miles. Granted, it doesn't specify conventional or synthetic, and I'm willing to bet my owners manual says every 3 months or 3k miles. Up to this point I've been doing it every 3 months as I don't worry about the mileage that much, but since discovering that's what my service manual says I'm considering changing the interval. Thoughts? Oh, I run conventional by the way- Castrol 10w30 [There may be some of you that think Castrol is **** oil but I've never had a problem with it in the 12 years I've been doing my own changes].
Old 08-05-2009, 04:51 AM
EPNCSU2006's Avatar
If I remember correctly, the owners manual lists 5000 mile change interval for normal driving, and 3000 for "severe" driving conditions. I don't remember if there is a time interval, though. Castrol GTX should be just fine. We used it in our race car at school with very good results. It was a turbocharged 600cc motorcycle engine that used a wet clutch, so the oil got abused. The bearings always looked new when the engine was disassembled, so I don't think you'll have any issues with Castrol.
When I first started driving, I changed the oil at 3000 like clockwork. I've since gone to 5000 mile intervals on the truck, although last change was at 4000 miles since it had been a year since the last change. It goes through a quart of oil every 1000 miles, so there's always a little fresh oil being added along the way. I usually use Valvoline conventional oil or NAPA oil, which is Valvoline in a different bottle.
I run Mobil 1 extended performance in my Honda and change every 10000 miles. I could probably go longer, but without a used oil analysis, I'd rather be a little cautious.
Old 08-05-2009, 09:52 AM
DBGrif91's Avatar
Well, I didn't know what opinions there were about Castrol here- in a couple of other auto forums that I frequent, most don't care for it. I guess in the last 4 years they've made like 3 different formula changes, and despite my trying to press that I'm sure these changes were made for the better, they still looked down upon it.
Oh well, I don't care. Like I said, no problems in the 12 years I've been using it, and unless something happens that makes me question its integrity, I'll keep using it.
302 Racing crate motor best oil filter RCouture Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 08-10-2016 12:45 AM
Oil filter for rotella 15w-40 standardtransonly Oil & Lubrication 12 12-26-2015 02:14 PM
should I use seafoam in a 302 efi that has 169,000 Jason302 1987 - 1996 F150 & Larger F-Series Trucks 7 06-18-2011 06:38 AM
Ford 5.0L 302....OIL...? gvrangr98 1966 - 1977 Early Broncos 4 10-08-2009 02:32 PM
amount of oil in a 302 biohazard Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 06-10-2001 07:27 PM
Tags
10w, 1991, 1996, 30, 302, 95, conventional, f150, ford, manual, motor, oil, recommend, truck, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
