brake lights don't work - Ford Truck Enthusiasts Forums
Old 07-31-2009, 12:20 PM
74scamp 74scamp is offline
74scamp is starting off with a positive reputation.
all the fuses,bulbs are good and I replaced the brake light switch on my 89 f150 but I still can't get the brake lights to work, any ideals? all the other lights work. thanks in advance.
Old 07-31-2009, 01:50 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
Make sure you have power to the wires out of the switch and then make sure you have power at the bulb socket. My guess is if you have it in the front but not in the rear there is something messed up in the middle. Corrosion, a break. Thats where I would go if I determined the fuse, switch, and bulbs were good.
Old 07-31-2009, 01:53 PM
SaikotikGunman's Avatar
SaikotikGunman SaikotikGunman is offline
SaikotikGunman is gaining momentum as a positive member of FTE.
Do the four ways work in the back? If so, the wires are good. These trucks use the same wiring for signals and brakes. That'll narrow it down a bit.
Old 08-03-2009, 09:11 AM
turn and tail work, the 4 ways don't and I can't find the flasher to replace it, the book says it should be behind the fuse block or on the right side of the instrument cluster, but I'll be damm if I can find it.
Old 08-03-2009, 09:42 AM
Volvo92906's Avatar
Well, in my truck the flasher for the four-ways is on the passenger side, behind the glovebox, on the right side.
Also, on my truck I would have an intermittent brake problem. Sometimes one would work, sometimes not. It was a mess. I replaced the turn signal switch (brake lights that function as turn signals also run through the t/s switch) and it worked fine.
Just an idea.
Old 08-03-2009, 09:55 AM
I got the brake lights to workis the 4 way flasher square? I found it by the glovebox if thats it.
Old 08-03-2009, 10:28 AM
Volvo92906's Avatar
Quote:
doesnt matter what shape it is, a flasher is a flasher.
left brake light inop. Solved...I'm an idiot AllaboutMPG 1999 - 2003 7.3L Power Stroke Diesel 8 04-13-2016 08:26 PM
59 F100 brake lights tbean 1957 - 1960 F100 & Larger F-Series Trucks 7 05-09-2013 01:31 PM
1986 F150 XLT Brake Light Problem wagontrader 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-14-2011 02:24 PM
Brake light failure(Tail lights) jamrock Electrical Systems/Wiring 4 02-22-2007 11:50 PM
Brake, reverse, dome lights not working ChrisLambert Electrical Systems/Wiring 2 07-09-2004 01:56 PM
Tags
1988, 1995, 2000, 89, 99, brake, brakelights, dont, f150, ford, lights, truck, turn, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
