Just Bought A....
Just Bought A....
New Truck! It's either a 1969 or 1971. Still need the VIN numbers for someone to help me find the actual year.
PICTURES-
Current Plans for the truck include-
Off-Roading! Even though it is a 2WD I have a couple friends that do the same with these year and model trucks and they seem to have a blast!
Anyway Here is what's on my to-do list-
V8 Swap for that inline 6
Hurst 3 Speed truck shifter (Crappy No-Name one currently)
upgrade to 16x8 rims
new tires
fix minor interior issues
LT Headers
Moser Axles
New Gear and Locker for the 9 Inch ford
Also, Couple questions for you guys- Who all has pictures of their 2WD Drive off-road machine? Or has lifted pictures?
And the fuel pump- Previous owner did not have the original seat so he rigged a newer style seat in and the gas tank would not fit. They than had the wonderful idea of building a wooden box and enclosing the gas tank. So a new fuel cell will also be needed. Should I upgrade to a electric pump then too?
Tyler
PICTURES-
new tires
LT Headers
Moser Axles
Tyler
i would bet money its a 67. i would say change the seat back to stock and put a stock behind the seat tank in it. and you can or can not go with electric fuel pump. but doing a v8 swap you will need a new trans to go with it....check out www.autofab.com they build a number of lifts for these trucks. they also have some pictures on there too...
And for the gas-tank. I probably will go back with a original seat. Problem is finding one!
Also- Does anybody still make a original wiring harness? As you can see in the one picture the one owner just did a home-made job on the wiring. I would like to get a nice clean wiring setup and put it back under the dash so it looks right!
Tyler
Oh ya, I take my 2wd off road all the time, while mine not lifted It does have wider tires and I simple take my time, a winch is a must, A farm jack helps also. This inst saying a 2wd gets stuck easy, this is simple planning ahead. And having a limited slip or locker rear end is a MUST! With a lift, you in a 2wd have better ground clearance, lighter truck and more power. Many Baja truck are also only 2wd to give you a idea what a 2wd can do.
But also, "Tread Lightly" So there will always be places to off road later
I will check that out thanks!
Yeah, I think I was looking through the LMC Catalog today and saw that...I think I might try to fix the wiring first before a new harness for that price!
Definitely will be building a rear end. Looking at a Detroit locker with a new precision gear. Also new Moser Engineering axles. As far as a winch do they make whole bumpers with a winch mount? I was also looking into a high-lift jack like you see on Jeeps and may take a jeep mount and modify it to work in the bed of the truck.
I would like to make it to some of the runs with the local 4 Wheel parts store when they have events so we shall see how the truck holds up once it's finished!
Tyler
painless does make a kit for your truck but its like $600 if i remember right...but your might not be that bad just needs some help
Tyler
Tyler
Radio mount for 68 - 72 was recessed. Someone switched instrument cluster from 69-70 maybe. Ashtray pull is narrow for 67, wide for 68-72.
