Shackle Leveling Kit Install How-to?? - Ford Truck Enthusiasts Forums
Old 07-30-2009, 09:04 PM
jkidd_39's Avatar
jkidd_39 jkidd_39 is offline
jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.
Anyone got a guide on how to install a front leveling kit?
The shackle type off ebay?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33585
Thanks all.
Old 07-30-2009, 09:54 PM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Thanks all.
That is the one I have. It's pretty straight forward. You unbolt the rear shackle on the front spring, Jack the truck up, fit the new one in, you may need a bottle jack to line it up. Then put the bolts back in. It also comes with directions in the box, if I remember correctly.
Old 07-30-2009, 10:13 PM
jkidd_39's Avatar
I got the box.. but no directions.. darn
Old 07-30-2009, 10:22 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Yeah, the shackles are the inexpensive parts at $50, the directions cost another $300.00, if you want them included.
Its pretty straight forward Andrew, no problems when I did mine (yes, I have the same kit).
Ohh, wait, Have a ratchet strap handy. After you get the first side done, when you remove the bolt for the second side, the spring will want to move out of line a little and youll need the ratchet strap to pull it back into place.
Old 07-30-2009, 10:26 PM
HKusp's Avatar
I used a porta power now that I think about it. I didn't want to volunteer you Brandon to help him out without checking with you first.
Brandon is very good at walking you through it. I am not neqrly as good at remembering all the details like he is Andrew.
Old 07-30-2009, 10:33 PM
HKusp's Avatar
Here are some pics of them with the comparrison between the old ones and the new.
The new one is so much beefier. Nice pieces for the money for sure.
Old 07-30-2009, 10:51 PM
bdrummonds's Avatar
and here is what the finished job will look like
Old 07-31-2009, 02:25 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
I got the same kit also Andrew, just be careful when unbolting, those springs are under alot of load, use the bottle jack or strap like the guys mentioned to relieve the tension and to line the holes back up when you put the new shackle in.. Jacking just the body up on the front end helps alot.
Old 07-31-2009, 02:43 PM
redfire42's Avatar
redfire42 redfire42 is offline
redfire42 is gaining momentum as a positive member of FTE.redfire42 is gaining momentum as a positive member of FTE.
How is the ride with those Vs add-a-spring types?
Old 07-31-2009, 08:29 PM
jkidd_39's Avatar
Installed.. pics to come..
The spring is bent backwards tho.. it now longer has a Shallow U shape.. It is bent slightly past horizontal..
Is this normal?
Thanks all
Old 08-01-2009, 08:15 AM
big poppa's Avatar
Is this normal?
Thanks all
Mine does a bit, yes. O yea, congrats.
Old 08-01-2009, 07:25 PM
jkidd_39's Avatar
Alright.. I got some pics for everyone..
These were sanderson welding shackles..
However. They were about an 1/8 too narrow so some bending was required to make them fit. Anyone else have this problem?
All and all it really sucked installing these. But I am very happy with them..
Ohh.. and one of the springs flexed in and that was really sucky to find a way to bend it out. One skid steer fork through the wall of my shop later we got it working. ugh...
Here are some pics.
Before.
<a href="http://www.flickr.com/photos/35223180@N03/3779616372/" title="Before by shady0667, on Flickr"><img src="http://farm4.static.flickr.com/3088/3779616372_0bf8c25dd9.jpg" width="500" height="375" alt="Before" /></a>
After.
<a href="http://www.flickr.com/photos/35223180@N03/3779617212/" title="After by shady0667, on Flickr"><img src="http://farm3.static.flickr.com/2578/3779617212_acae77b965.jpg" width="375" height="500" alt="After" /></a>
Really improves the look of the truck. And I know understand why I need a lift. The truck looked mean when it was sitting all jacked up...
Enjoy!
Old 08-01-2009, 07:34 PM
big poppa's Avatar
Looks good, hows the ride??
Old 08-01-2009, 07:57 PM
jkidd_39's Avatar
Quote:
I think it's a little rougher but it might be Missouri's great roads!
Old 08-01-2009, 08:08 PM
beanhead6D5's Avatar
beanhead6D5 beanhead6D5 is offline
beanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to all
Andrew,your dad is SO going to take your truck from you,LOL.
Does it ride as rough as my truck with a lift?
New 2-Wheel drive leveling kit on ebay Stewart_H 1999 - 2003 7.3L Power Stroke Diesel 69 04-27-2011 08:59 PM
oil cooler parts checklist havns3 6.0L Power Stroke Diesel 10 08-22-2010 07:37 AM
looky what i just got ! Danger_Dave 1967 - 1972 F-100 & Larger F-Series Trucks 20 04-20-2010 06:00 PM
Mercury Valve Cover? (link to pic) tylstruck FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 02-23-2008 07:06 AM
Mirrors XylemXorro Excursion - King of SUVs 5 12-06-2006 11:36 AM
Tags
2001, f250, f350, ford, front, homemade, install, kit, leveling, lift, mod, schackles, schakle, shackle, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
