Hydroboost conversion done! - Page 8 - Ford Truck Enthusiasts Forums
  #106
Old 06-10-2012, 08:02 PM
KingBigJoe's Avatar
KingBigJoe KingBigJoe is offline
KingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputation
Nice thread. I am interested in putting a hydroboost setup in 1978 F250 4x4. It would be nice if I can see how the lines to & from the hydroboost to the power steering pump are routed so that way I can do the same thing.
  #107
Old 03-06-2013, 04:03 PM
rh1231979 rh1231979 is offline
rh1231979 is starting off with a positive reputation.
Exclamation
Bueller? Bueller? Anyone?
I'd like to see this as well! Surely someone here has a diagram or pics of the plumbing between the hydroboost, steering pump and gearbox...
I know there are other threads about the HB conversion, but I'd like to see more/better pics and information.
  #108
Old 07-09-2013, 10:50 PM
oddfordjunkie oddfordjunkie is offline
oddfordjunkie is gaining momentum as a positive member of FTE.
Glad to find this thread, already got the HB out of a 94 F-450 and one of the lines, the pump and other line were junk from a wreck.
Putting this in my 78 CCSB and debating on which pump to go with, I may go pull the entire serpentine system off a newer 460 and get my pump and alternator upgrade in one shot.
  #109
Old 07-11-2013, 04:18 AM
Got my booster installed today. Still need to run the lines and get a different master cylinder. A few things that I ran into were, the factory mount bolt with the star washer had too big of a head/washer to fit in the lowere right mounting hole straight, so I used a one of the 1/2" head Starter mounting bolts as it is the same threads and length with the smaller head and a lock washer. Also in order to put the notch in the booster for the safety tab on the mounting plate (flipping the plate require a new notch 180 deg from old) I was able to use a 1/8" drill bit on my cordless and at about a 20 deg angle and "machined" a new groove, turned out great, I wouldn't dare try this with cheap bits.
While searching for an actual photo of the pluming I found this GREAT write-up/install on Pirate4X4
Pirate4x4.Com - The largest off roading and 4x4 website in the world.
  #110
Old 02-26-2014, 04:05 PM
[IMG][/IMG]
Been running my for a while now and LOVE it. The best vehicle mod I've ever done to anything!
  #111
Old 02-26-2014, 10:52 PM
4wydnr 4wydnr is offline
4wydnr is starting off with a positive reputation.
Quote:
It's one of the best 2 on my truck easily!
  #112
Old 05-31-2014, 02:26 PM
mdlave mdlave is offline
mdlave is starting off with a positive reputation.
So, the hydroboost units from Ford trucks and Chevy Astro vans definitely work.
The pick and pull near me has quite a few Chevy full size trucks and full size vans. I know some of them had hydroboost as well. Has anyone tried to use one of those or are they too different?
  #113
Old 05-31-2014, 06:35 PM
I'm not sure of the mounting pattern, MC mounting or pushrod length on the GM unit. However I do know that the GM units use Metric threads for the fittings so either way you would have to adapt that.
  #114
Old 05-31-2014, 08:20 PM
EP145's Avatar
EP145 EP145 is offline
EP145 is starting off with a positive reputation.
GM one has I different bolt spread, I had drill out the mounting plate. Then I found the 2000 S10 master cylinder has a 1 inch bore the same as the Ford one.
I also had to shorten the pedal rod 3/4 of an inch.
  #115
Old 05-31-2014, 08:28 PM
EP145's Avatar
Pirate 4x4 does have a nice write up thanks for sharing I still need to plumb mine.
  #116
Old 05-31-2014, 10:10 PM
EP145
Since you went with the GM Booster you can get the Saginaw pump and mount off a Ford van with the 351W and use a GM line from the pump to Booster as it will have the correct fittings on both ends. This will leave you to deal with the fitting difference between the booster and your steering box but it's a start and the Saginaw was a good upgrade on mine.
  #117
Old 06-01-2014, 09:57 PM
EP145's Avatar
EP145
Thanks I'll check into that
  #118
Old 06-12-2015, 10:18 AM
Radster Radster is offline
Radster is starting off with a positive reputation.
2000 excursion
This is a great thread, with lots of good information. I am putting Hydroboost in my 73 F250 4x4. I put a axle from a 77 crew cab with dual piston calipers in my truck to get rid of the front drums. The vacuum system stops me, but does not lock up the tires if needed. I was wondering if a Hydroboost system from a 2000 Excursion diesel would work? I could get a good deal from a coworker who bought back his wrecked Excursion, and he is parting it out. I was wondering if anyone has looked into using these parts. Would the holes be a little off like the F series trucks for this year? I will also be getting the pedal system if it will work. Any information would be great.
  #119
Old 12-01-2015, 02:06 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Way late reply, but the expedition ones are the same as the Superduty ones of the same vintage. I have the hysroboost unit from a 2001 superdookie in my '74 crew cab project, but the project is a long term one that isn't running yet and therefore I can't personally couch for anything other than it can be made to fit. Pretty sure other guys have used these with no problems though.
  #120
Old 01-07-2016, 04:43 PM
wcs69rat wcs69rat is offline
wcs69rat is starting off with a positive reputation.
Hydroboost Question
Thanks for all of the helpful info in your hydroboost post. There are some differences between my truck and yours, so I have a few questions. It sounds like you at least had power brakes and front discs from the factory. I have manual drums on all 4 corners on my '63. Will the super duty hydroboost set up work with the super duty master cylinder? I do not plan on using a proportioning valve....just an adjustable Wilwood pressure reducer going to the rear brakes and full pressure running to the fronts.
Thanks
Hydroboost 79 ManfredVonRichtofen 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-22-2016 09:21 PM
Hydroboost conversion problems... Please help!!! carguy29 1973 - 1979 F-100 & Larger F-Series Trucks 10 09-30-2015 05:05 AM
F450 Hydroboost into Bumpside Pickup Cracker289 1967 - 1972 F-100 & Larger F-Series Trucks 20 07-18-2015 03:59 PM
1990 F-250 Hydroboost Conversion .Artisan. 1987 - 1996 F150 & Larger F-Series Trucks 17 06-16-2015 02:05 PM
HOWTO - Stop Me - Hydroboost Write Up bghnkinf250 '80-'86 HOWTO's 61 04-21-2015 11:07 PM
Tags
1977, 450, bleeding, boost, booster, brackets, brake, brakes, conversion, f250, ford, hydro, hydroboost, mounting, prices, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
