Hydroboost conversion done! - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-03-2009, 04:44 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Quote:
Originally Posted by ford390gashog View Post
The only part I got from the parts store new was the master cylinder.But all the parts I listed can be had new or rebuilt from any parts store.
These are the prices for new parts
190.00 + 50.00 core on F-450 Hydroboost with bracket
Pressure hose pump to booster 19.00
Pressure hose booster to steering gear 22.00
Aren't the diesel hydroboost units the same for F250-F550?
Josh
  #32
Old 08-03-2009, 08:18 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Quote:
Josh
No, that is the part I think people are missing. You need to get it from a 87-97 F-450 SUPERDUTY truck those were the only ones that had hydroboost. There also was no 550 back then. You can use 98+ Super Duty parts but more fab work is involved.
  #33
Old 08-03-2009, 08:51 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Do you know what the differences are?
The one in your pics look pretty identical to the units I have which are both 2001 or newer. From what I can tell there isn't much fabrication that would be different. It looks like I could install mine the way you did yours. I am just making a bracket/spacer to keep mine off the firewall as I don't really want my pedal pushed over an inch higher.
  #34
Old 08-03-2009, 10:42 PM
Bullitt390's Avatar
Pre 2001 Booster:
Post 2001 Booster:
Besides the pushrod, what else is different?
Josh
  #35
Old 08-03-2009, 11:23 PM
65f100_352 65f100_352 is offline
65f100_352 is gaining momentum as a positive member of FTE.
The later one doesn't have the green bolt.
  #36
Old 08-03-2009, 11:50 PM
Bullitt390's Avatar
That's just a plastic plug for shipping
  #37
Old 08-04-2009, 02:16 AM
Ok so it looked like a bolt...
  #38
Old 08-04-2009, 02:42 AM
The pre 2001 bolt spacing on the bracket is different its a metric spacing. It can work just with some fab I guess.You could also redrill the 3/8'' bolt hole in the pedal so the pedal does not sit so high instead of a spacer.The pushrod on the booster moves up and down a lot so you can relocate its mounting point on the pedal.
  #39
Old 08-04-2009, 09:51 AM
Bullitt390's Avatar
Did you mean POST 2001 booster?
I forgot to mention that according to NAPA there is a $100 price difference between the two as well... $139 for Pre 2001 and $239 for Post.
I only bring up the Post 2001 booster because it is actually easier to find wrecked Superduty F250-F350 trucks than it is to find an F450 around here.
Josh
  #40
Old 08-04-2009, 11:55 AM
Big Dam 350's Avatar
Big Dam 350 Big Dam 350 is offline
Big Dam 350 is starting off with a positive reputation.
Please excuse me but I have a couple simple questions and this is the first I'v heard of this upgrade.
1. Do the brakes revert back to manual if the engine stalls?
2. I'm still wondering the purpose of the snap rings.
3. With the addional use of power steering pump and oil is a cooler needed?
  #41
Old 08-04-2009, 02:24 PM
fordtrucknut's Avatar
fordtrucknut fordtrucknut is offline
fordtrucknut is starting off with a positive reputation.
The brakes will do the same thing they do when the engine stalls when you have a vacuum booster...they will work...but they are hard to push and worse than manual brakes but stoppable....An oil cooler is DEFINATELY a good idea with this swap!!....I'm a little lost on the snap ring thing myself...
  #42
Old 08-04-2009, 02:41 PM
75F350's Avatar
75F350 75F350 is offline
75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all
That small reservoir is an accumulator which still provides fluid and assistance for the master cylinder even if the engine stalls.
Depending on the reservior one can expect a couple of pedal throws before the fluid is gone.
Safety feature designed into every unit. Some have these internally.
  #43
Old 08-04-2009, 03:13 PM
Bullitt390's Avatar
Here is a NAPA picture of a Chevy booster, looks identical except it doesn't come with the plate with studs. The push-rod seems to match the Post 2001 Superduty style as well.
I am really intrigued with the hydraboost set-up. I ditched my vacuum booster and converted to manual brakes since I have to remove my valve cover fairly frequently. This set-up restores the power brakes and gives room for valvetrain service.
I am sorry if I am posting too many pictures or asking too many questions, but my favorite junkyards do not have the larger F450+ trucks or really anything newer than 2000, especially Superduty trucks with diesels. The yards that do have the newer vehicles are not the u-pull-it, but rather "we pull it for you and charge an arm & a leg".
So I am just trying to figure out all my options when I go and hit up the yards.
Josh
Josh
  #44
Old 08-04-2009, 03:52 PM
eBay - but then again it is MUCH easier to find one off a post 2001. As I said - from what I have seen they are the same F-250 thru F-450 or 550 on the post 2001's.
Finding one of the older F-450's is tough!
  #45
Old 08-04-2009, 04:42 PM
Bullitt390's Avatar
Any problems running a hydroboost with the 2wd Ford Thompson pump?
Josh
Hydroboost 79 ManfredVonRichtofen 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-22-2016 09:21 PM
Hydroboost conversion problems... Please help!!! carguy29 1973 - 1979 F-100 & Larger F-Series Trucks 10 09-30-2015 05:05 AM
F450 Hydroboost into Bumpside Pickup Cracker289 1967 - 1972 F-100 & Larger F-Series Trucks 20 07-18-2015 03:59 PM
1990 F-250 Hydroboost Conversion .Artisan. 1987 - 1996 F150 & Larger F-Series Trucks 17 06-16-2015 02:05 PM
HOWTO - Stop Me - Hydroboost Write Up bghnkinf250 '80-'86 HOWTO's 61 04-21-2015 11:07 PM
Tags
1977, 450, bleeding, boost, booster, brackets, brake, brakes, conversion, f250, ford, hydro, hydroboost, mounting, prices, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
