Hydroboost conversion done! - Page 2 - Ford Truck Enthusiasts Forums
Old 07-31-2009, 07:06 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Quote:
Originally Posted by 4wydnr View Post
Nice write up this will make a good winter weekend project. Thanks
I spent 6 hours start to finish thats including the 2 hour trip to the u-pull to get parts.
Old 07-31-2009, 07:37 PM
77f2504by4's Avatar
77f2504by4 77f2504by4 is offline
77f2504by4 is gaining momentum as a positive member of FTE.
you could always make new brackets instead of using a spacer, i think it would look better, it would look as though the truck actually came with hydroboost.
Old 07-31-2009, 09:21 PM
460swmo 460swmo is offline
460swmo is starting off with a positive reputation.
I drive a 1978 Mercury Grand Marquis that has 4 wheel disc brakes with hydroboost and it stops very nice so I wonder how well a hydroboost from a fullsize 4 wheel disc 1975 to 1978 Lincoln or Mercury Marquis or Ford LTD would fit these trucks?
Old 07-31-2009, 09:58 PM
77f2504by4's Avatar
Quote:
it may work, but it also may not output enough pressure.
Old 08-01-2009, 02:10 AM
fordtrucknut's Avatar
fordtrucknut fordtrucknut is offline
fordtrucknut is starting off with a positive reputation.
Marquis
I had a 76 that I was going to use the Hydroboost from several years ago..ended up selling the whole car...those cars are very heavy and the unit should work just fine for a truck unless it built insanely huge....Superduty units are just easier to come by now...and a little more modern.
Old 08-01-2009, 02:31 AM
Of course my car is my daily driver and a nice car so I would never use it for a donor and they are heavy, it weighs 4,700 pounds.
Old 08-01-2009, 03:22 AM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Quote:
Not to toot my own horn, but you apparently haven't seen my work. Machined aluminum will look just fine (I bought the aluminum block/billet today)
As for looking as if the truck came with one... I strive in all of my work on the trucks to look BETTER than it did coming from the factory. I think I'm doing ok at pulling that off as well.
Factory "brackets" were an L bent piece of steel. I'll take a machined piece instead most of the time.
I haven't run an old hydrobbost before but from what I have heard the new units seem to function a bit better. Plus, based on other responses here - the new ones sound a little smaller/more compact.
Old 08-01-2009, 07:18 PM
77f2504by4's Avatar
i am not doubting the quality of your work, i personally like things to look as they would have if ford did it. thats just my preference.
Old 08-02-2009, 08:07 PM
And I'll stick with BETTER quality than rolled off the assembly line
Old 08-03-2009, 02:56 AM
Not going to split hairs some of the things ford did was fine but other parts of these trucks you just have to sit back and think what were they smoking? The really bad pedal bushing design, firewall flex at the booster and the fuse box which uses such uncommon and hard to find fuses. So if you can find a part you can make better than stock I say go for it.
Old 08-03-2009, 03:44 AM
alex211's Avatar
alex211 alex211 is offline
alex211 is starting off with a positive reputation.
I'm confused, does one PS pump run the brakes and steering or do you need two pumps?
Old 08-03-2009, 06:51 AM
77f2504by4's Avatar
Quote:
usually its one pump, but you could use 2, for a safety factor.
  #28
Old 08-03-2009, 11:20 AM
4wydnr 4wydnr is offline
4wydnr is starting off with a positive reputation.
Why wait? This is pretty esily done in a weekend!
I want to drive my truck first, maybe after everything is finished with my conversion I'll take a weekend to do this job. I live in Illinois and won't drive my truck after the salt hits the road so that leaves me roughly until December to drive my truck if I ever get time to finish it.
Oh and for the record Chasetruck, the pics of your work toot your horn for you.
  #29
Old 08-03-2009, 12:26 PM
Big Dam 350's Avatar
Big Dam 350 Big Dam 350 is offline
Big Dam 350 is starting off with a positive reputation.
Gashog the prices that you quoted are the junk yard prices or did you get them at a parts store, if so where? Do you have any part numbers?
My 79's brakes were pretty jacked from the PO and my plan is to do alot of hauling and towing with 37's so a little extra stopping power would be great.
Why did you do the snap rings? If your worried about the bolts backing out way not do lock-tight or a jam nut and lock-tight. Just curious.
Thanks for the post.
  #30
Old 08-03-2009, 03:56 PM
The only part I got from the parts store new was the master cylinder.But all the parts I listed can be had new or rebuilt from any parts store.
These are the prices for new parts
190.00 + 50.00 core on F-450 Hydroboost with bracket
Pressure hose pump to booster 19.00
Pressure hose booster to steering gear 22.00
Hydroboost 79 ManfredVonRichtofen 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-22-2016 09:21 PM
1990 F-250 Hydroboost Conversion .Artisan. 1987 - 1996 F150 & Larger F-Series Trucks 17 06-16-2015 02:05 PM
HOWTO - Stop Me - Hydroboost Write Up bghnkinf250 '80-'86 HOWTO's 61 04-21-2015 11:07 PM
Stop Me - Hydroboost Write Up bghnkinf250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 52 09-09-2013 05:07 PM
Chevy hydroboost conversion - done! LCAM-01XA Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 11-15-2008 12:52 PM
Tags
1977, 450, bleeding, boost, booster, brackets, brake, brakes, conversion, f250, ford, hydro, hydroboost, mounting, prices, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
