Instructions on replacing upper and lower control arms - Ford Truck Enthusiasts Forums
Old 07-30-2009, 04:58 PM
esnider225 esnider225 is offline
esnider225 is starting off with a positive reputation.
Hi guys,
Can anyone direct me to a website or thread that explains how to replace control arms. I have a 2005 F150 5.4L Super Crew. I know the uppers are bad. How can I tell if the lowers are bad too? My hubby and I just replaced the solenoid/actuator so it doesn't look that difficult, but would like a little more info.
Old 07-30-2009, 09:36 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
I'm guessing you need ball joints?????
The upper arm isn't too bad, the lower arm doesn't need to be replaced, you can replace just the ball joint.
Upper arm,
1, remove the wheel
2. remove nut from the ball joint
3. remove the spring and shock assembly
4. Pull out two bolts holding control arm
Put new control arm back in place and replace in reverse....don't forget to torque
Old 07-30-2009, 10:20 PM
Thanks Ryan50. Everyone says the lower ball joint has to be pressed too and I don't have a press, so I bought the new lower control arm/ball joint assembly. Is this correct? I bought Moog parts so I should have a life time warrantly now. I don't even know if the lowers are bad, I just read it is most likely they will go soon. If the Lower BallJoint doesn't need the control arms too then do they need to be pressed? (2005 F150)
Old 07-30-2009, 10:21 PM
Old 07-30-2009, 10:44 PM
Ryan50hrl's Avatar
Yes and no....by pressed...you can buy or rent a ball joint press for not much money...if you have an auto zone or advanced auto parts they rent them pretty cheap (free).....otherwise.....
http://www.harborfreight.com/cpi/cta...emnumber=38335
still cheaper than replacing the whole arm.....
Old 07-31-2009, 07:15 AM
great white great white is offline
great white is starting off with a positive reputation.
Don't want to hijack this thread, upper control arm seems pretty easy. What concerns me a bit is access to the lower balljoint. Can anyone shed some light on the lower, like what parts to remove to get to the point where you can remove the joint itself. Do we need to remove knuckle, axle nut etc. Like others I have my parts on order and plan to tackle in the next couple of days.
Old 07-31-2009, 07:45 AM
Ryan50hrl's Avatar
You should be able to remove the nut and then pull the knuckle out of the way....Otherwise...if youre doing the top and bottom you could pull the knuckle all the way off if you have a 2wd.....but i'd be more work than its worth to pull the knuckle if you have the 4wd with axle shaft going through the knuckle....
Old 07-31-2009, 08:06 AM
I have a 4x4, so I think what you are saying is I can get to and remove the lower ball-joint without removing the knuckle?
Old 07-31-2009, 08:20 AM
Ryan50hrl's Avatar
Theres no actual reason why you'd have to pull the whole knuckle off IF your able to get the ball joint press in place...
What i'd try is this....
put the truck up on jackstands....pull the snap ring off the ball joint and get the lower arm and knuckle separated....then get the knuckle pushed back as far as you can toward the back of the truck....and try and get the ball joint press in there....i'll bet money you'll have enough room to do it without removing the rest of the knuckle
Old 07-31-2009, 08:31 AM
Will give it a try, and thanks a bunch for your help.
Old 12-09-2009, 01:54 AM
dirtslmfan_25 dirtslmfan_25 is offline
dirtslmfan_25 is starting off with a positive reputation.
I'm getting ready to tackle this job and was wondering if you we're able to r&r while pushing the knuckle out of the way. Thank's for any help.
Ball joints sam hain 1997 - 2003 F150 3 01-01-2017 09:31 AM
Does anyone know how to replace pitman arm & idler arm Big Norm 1997 - 2003 F150 4 11-15-2014 08:53 AM
Help with front lower control arm replacement abcfisher1 1997-2006 Expedition & Navigator 12 06-24-2012 08:18 PM
2000 Ranger upper ball joint replacement? Guest user Brakes, Steering, Suspension, Tires, & Wheels 2 01-08-2012 11:30 PM
Upper Control Arm ...adjustment? Hartwa 1997 - 2003 F150 3 01-22-2007 03:27 PM
Tags
2005, 2006, arm, arms, ball, control, f0150, f150, ford, joint, joints, lower, remove, replace, spring, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
