AM antenna problems - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
AM antenna problems
Old 07-30-2009, 03:20 PM
Cadence8 Cadence8 is offline
Cadence8 is starting off with a positive reputation.
Cool AM antenna problems
My 2007 Exp. exhibits AM radio reception problems that can only be antenna or antenna-connection related. FM is not an issue. AM will - always has - go a long period receiving as if there is no antenna connected (only picking up the strongest stations in a very limited area, not anywhere near normal), and then suddenly get normal reception. The head unit was swapped out and no difference. The dealer says he has checked the connection at the back of the radio and in the right rear quarter where the antenna is. AM antennas are usually built in to the radio case, not external or visible. But I know, because of the mass of metal around a car radio, that even for AM there has to be an external antenna. This behavior has to narrow the problem down to one or two things, and it is frustrating that the dealer cannot find it. Ideas?
Old 07-30-2009, 08:04 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
spotty reception is indicative of a loose antenna
have you checked the connections yourself?
I'm having a similar issue with my FM. I've just been too lazy to pull the dash apart and check the antenna connections. Been using my iPod/iPhone instead
Old 07-30-2009, 11:17 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I would pull the radio, spray some contact cleaner on the antenna end and work it into the radio a few times. Test the reception with the radio uninstalled but plugged in. You may have a cold joint on the solder on the inside of the radio.
Antenna advice wastingas Expedition & Navigator 5 12-08-2012 04:00 PM
Radio antenna connection jowilker 2004 - 2008 F150 4 10-22-2012 05:45 PM
Radio Antenna hokie93 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 09-29-2009 01:43 PM
Shortening antenna questions BigRed1 Electrical Systems/Wiring 4 09-14-2008 10:37 PM
I need a shorter radio antenna. dmutsch 1999 to 2016 Super Duty 4 02-25-2000 12:45 AM
Tags
2006, antenna, expedition, expediton, ford, problem, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
