7.3 engine slows down
I have a 2000 F250 4x4 super cab with a 7.3 diesel and automatic transmission that starts and initially runs fine. Yesterday, after driving for about 30 miles at highway speeds, the engine would slow to an idle, and after letting up on the throttle, would then drive normally for another mile or so and then repeat itself. I discovered that it was possible to put the transmission in neutral, at which point the engine speed would increase to about 1800 rpm for several seconds before falling to an idle, where upon I would put it back in drive and continue on until it did the same thing all over again. The engine runs strong when not trying to idle. After arriving at my destination, I changed out the fuel filter and drove it for about 10 miles before it started doing the same thing all over again. The outside air temperature was pretty hot (around 95-100 degrees), in case this is a heat related issue, although the engine operating temperatures were normal, i.e. around 180 degrees. Any ideas out there? I appreciate any input...
exbxtoy
13
12-15-2023 01:28 AM
tonyford
1983 - 2012 Ranger & B-Series
31
11-09-2019 02:28 PM
schottj1
02-06-2015 07:52 AM
JNG6
1999 to 2016 Super Duty
21
07-08-2014 10:52 PM
