Help Me Numberdummy - Ford Truck Enthusiasts Forums
Help Me Numberdummy
Old 07-30-2009, 11:55 AM
79F150400M's Avatar
79F150400M 79F150400M is offline
79F150400M is starting off with a positive reputation.
Help Me Numberdummy
Im looking at some rear diffs on Craigslist here locally this gentlemen sent me a string of numbers off these parts he has and I'd like to know what gears and the spline count. Apparently these are all intact and un-opened. I was hoping if I gave you these numbers then we'd know what this guy has. This is what he sent me. Hopefully you can decipher it:
C5AW-4205 87 C6AW-DMCC D7AW CA 1947
C6AW-4205 87 MCC10 D1AW 4210 A53
Thanks
HELP !!!! 9 inch rear problems n4gnr Clutch, Transmission, Differential, Axle & Transfer Case 4 12-19-2010 12:59 AM
New rear end work with front end? MHull 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-02-2010 07:15 PM
Are 31-spline axles REALLY that rockher_man 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 04-30-2009 01:33 PM
Part number ID drof46 1961 - 1966 F-100 & Larger F-Series Trucks 3 01-02-2009 04:43 PM
id my pumpkin for me 400944 Clutch, Transmission, Differential, Axle & Transfer Case 1 05-03-2008 03:27 PM
Tags
1947, 4205, 4210, c5aw4205, c6aw, c6aw4205, c6awd, c6awdmcc, ca, d1aw, d7aw, dmcc, ford, mcc, part
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
