1992 7.3L fuel/water separator/filter - Ford Truck Enthusiasts Forums
Old 07-29-2009, 08:47 PM
skiprrdog skiprrdog is offline
skiprrdog is starting off with a positive reputation.
Hey All,
Ive got a 1989 F350, 6.9L with a 1992 7.3L (don't ask) fuel/water separator/filter.It was leaking out of the top at the heater connection, so I took it off and replaced the two o-rings, but don't think I have the right sizes as it still weeps out of that connection a little bit.
Does anyone know of the *correct* sizes that we are supposed to use?
Thanks in advance for any and all help!
Skip
Old 07-29-2009, 11:27 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Actually thats a better water separator setup than the 6.9 had. Nothing wrong with your setup.
Only thing to do is swap the O rings around with different sizes until you get one that holds. Next time you have it apart, take a magnifier glass to the sealing surface of the O ring and look for any signs of a scratch or dirt that might be preventing a proper seal.
Other option is to take it a part, clean everything, and re install with a bit of oil resistant RTV sealant (permatex ultra black for example). Has to be perfectly clean and dry of fuel and solvent the sealant won't bond though.
I had a leak at the filter change prong on mine (which I don't use) and ended up just sealing it off with some RTV. That was a couple years ago and its still holding.
Old 07-30-2009, 07:43 AM
yeah, I did some reading around on the forum last night and it seems like a couple of guys just disconnected the heater wire and sealed off the connection. I went to Auotzone and bought a box of o-rings and am going to take a shot at it one more time. If I cant get it sealed up, I may just plug it up like you say, as I live in Arizona, and I never even bothered to fix the cab heat in my other truck since Ive been here
Old 07-30-2009, 08:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
skiprrdog,
Welcome to FTE and the IDI diesel forum.
89 and 93 filter/seperator's are the same.
87 thru 94 used the new style filters with the water seperator in the filter.
83 thru 86 used seperate units, and the water seperator was the biggest source for air intrusion on the truck.
Old 07-30-2009, 09:21 PM
I think I got it goin on!
Thanks Dave,
I think I finally solved the problem. I found a couple of o-rings that I put on the heater, I had trouble trying to locate the bottom bowl part of it (the drain part was bad on the original one), so I went to NAPA and bought a one piece unit, filter with drain and sensor hookup on bottom. Solved the problem, but kinda spendy. Anyhow it started up this morning, didn't leak, I let it sit all day, and it started up again woo-woo!
This is my first diesel, and while I am respectably knowledgeable about gas engines, diesel, not so much.
The truck originally had a 7.3L in it, and the guy I bought it from had a rebuilt 6.9L put in it, or so he thinks, and that is what a tag on one of the valve covers says. Are there any discernible outward differences between the two engines?
Thanks!
skip
Old 07-30-2009, 09:36 PM
Rowdy_Cowboy_73 Rowdy_Cowboy_73 is offline
Rowdy_Cowboy_73 is starting off with a positive reputation.
I Have An 88 F-250 Ext. Cab 4x4 With The 7.3L IDI Diesel And I Have The Exact Same Problem Its Leaking Out Where The Fuel Heater Connection Is. I Am Going To Try Seal It Up With A New O Ring. I Priced Out A New Assembly Today And Its $324(Can. Dollars). I Hope A New O Ring Fits Because Up Here Winter Gets Down Sometimes To -30 Dergees Celcius So I Need It. If You Find The Proper Size O Ring Please Let Me Know! Thanks
Old 07-30-2009, 11:03 PM
Rowdy_Cowboy_73,
Old 07-31-2009, 10:00 AM
rowdy_cowboy, there is a pretty good set of images of a dis assembly/repair of one of these on this site here:
http://www.ford-trucks.com/forums/85...ml#post7610155.
As for the o-rings, for the larger one I used a 5/8"I.D x 3/4"O.D, 1/16" wide. On the smaller one I used a 1/2"I.D x 11/16"O.D, 3/32" wide; this one I trimmed off the O.D a little, as it was probably too fat, a 1/16" wide might work here also.
-30... brrrr, I feel your pain. I was born and raised in Chicago, in Arizona now, wild horses couldn't drag me back there!
Good luck,
Skip
Water in fuel already drained keeps coming back ssoulis 1999 - 2003 7.3L Power Stroke Diesel 13 01-11-2016 09:48 AM
slow drip from fuel/water seperator Squeggi 6.4L Power Stroke Diesel 3 03-18-2014 10:47 PM
Looking for a part number PaganFly Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 11-09-2013 08:15 PM
Is my fuel filter leaking air/fuel or not? artfd Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-01-2012 08:13 PM
2008 6.4 - what kind of oil should I use and where is the water separator drain? 90pioneer 6.4L Power Stroke Diesel 9 12-02-2011 06:55 PM
Tags
1992, 2002, 2008, 73, diesel, f250, filters, ford, fuel, good, liter, maintenance, powerstroke, separator, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
