air conditioner blows thew the defrost - Page 4 - Ford Truck Enthusiasts Forums
Old 11-07-2014, 02:39 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
  #46
Old 07-16-2012, 01:08 PM
BigBrett23601's Avatar
BigBrett23601 BigBrett23601 is offline
BigBrett23601 is starting off with a positive reputation.
ok so here goes I have a 98 f150 nascar edition. THe ac is blowing ONLY thru the Defrost. I checked under the hood and the vacum lins all appear to be ok. the line that runs thru the fire wall however I did take it loose from the t connection and I have vacum there. but when I take the Control unit out of the dash I have no Vacum . I also can not find the black line to save my life behind the glove box below the glove box . So can some one help me out and walk thru this please.
Thanks a Ton!!
  #47
Old 07-16-2012, 06:50 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
remove the oval panel on the top of the dash on the right hand side. Near the firewall above the plenum you will find a plastic splice that the black vacuum hose goes to from the control head and the line in from the firewall. It may be unplugged there.
  #48
Old 07-16-2012, 07:06 PM
TexasSawmillGuy TexasSawmillGuy is offline
TexasSawmillGuy is starting off with a positive reputation.
Mine is doing it again. This is maddening.
I've replaced all the lines except the one that runs from the vacuum reservior down behind the firewall and into the pass side foot area. None of the lines are disconnected.
This prpoblem is intermittent and I suspect the reservior "intermittently bad" - I hear a ball rolling around inside when I remove it, so is it possible this ball which is the ncheck valve is not seating properly sometimes but sometimes it is?
I can plug the line at the pump and the pump will shut off immediately so I assume this means the pump is strong.
  #49
Old 07-16-2012, 07:16 PM
It is very possibly the tank or the check valve. There is usually an external check valve in the engine compartment. If you have EATC the control head could also be leaking.
  #50
Old 07-16-2012, 07:54 PM
Quote:
I'm not sure what EATC is, if it's part of the 4WD system this is a 2WD.
  #51
Old 07-16-2012, 07:56 PM
EATC means electronic automatic temperature control. It would have a digital display rather than 3 control *****.
  #52
Old 07-16-2012, 08:32 PM
Okay, I don't have that.
After letting the truck idle with the a/c on for 15 minutes in order to let the cab get a little cool before I drove it to town to get some things, when I climbed in the air was coming out the a/c vents again. That's how intermittent this problem is. I think it must be the reservior, because if it was a leak in a line it wouldn't be intermittent, it would be permanent. Is this what you would think also?
  #53
Old 07-16-2012, 08:37 PM
Yes, unless it was a crack with a very small leak. Ive seen on some vehicles that have a water valve with the line pulled off give intermittent operation or a weak check valve. I would just go buy a used reservoir, shouldnt cost much and you can verify it. I have a vacuum tester that I use but that would cost more than another reservoir and you would use it about once every 20 years at home. Another alternative of course is take it to a technician to isolate the problem. Sometimes a diagnostic fee saves a lot of hit and miss fixes that could end up costing a lot more than a professional to look at it.
  #54
Old 07-22-2012, 05:39 PM
Jasonwillis84 Jasonwillis84 is offline
Jasonwillis84 is starting off with a positive reputation.
Quote:
Originally Posted by minitrk View Post
Just did this on my 2000 Expedition last night, I think it took all of 15 minutes to change the 4 o-rings, what a difference in sealing ability. I put it back together and it now works GREAT. Mine was a little different though, as my solenoids and plenum are spot welded on a metal frame, and not screwed to a plastic one.
Mine is also spot welded, how did you take yours apart?
  #55
Old 07-28-2012, 01:46 PM
strtglid strtglid is offline
strtglid is starting off with a positive reputation.
o-rings
Great write-up. Got my orings from grainger, pack of 100, if anybody needs some hit me up.
  #56
Old 07-31-2012, 08:08 AM
ryno_rx8 ryno_rx8 is offline
ryno_rx8 is starting off with a positive reputation.
Well I'm back to square 1, 02 f150 blowing out defrost only. Thought about the o-ring idea but as my mom has a navigator with the same controls, I swapped controls and still have the same issue (her AC blows where its told lol). Looking at the vacuum lines, does anyone know which color goes where? And which solenoid on the firewall controls what?
  #57
Old 08-13-2012, 01:07 AM
SoCal HD SoCal HD is offline
SoCal HD is starting off with a positive reputation.
Signed up to say thanks
Thank you so much Marauder2004 , less than an hour & I'm grinnin' ear to ear!! Max A/C was blowing in the Def only, but all the other positions worked normally. But your directions, and 45 minutes, everything works perfectly.
I bought a $10 maxcraft o ring kit from Napa for the 4 o rings. But now I'll have o rings for the rest of my life...lol.
  #58
Old 09-18-2012, 02:39 PM
03trouble 03trouble is offline
03trouble is starting off with a positive reputation.
Thumbs up Thanks Marauder2004!!
Thank you so much Marauder2004 , you Rock!!!!!
In no time at all, turned a $1,000.00 pain in the butt problem into an awesomely cheap and effective fix. Have 96 more #007 o-rings as well, anybody needs some.. let me know...
I owe you a case of Beer...
  #59
Old 11-27-2012, 03:08 PM
ljburrescia ljburrescia is offline
ljburrescia is starting off with a positive reputation.
A/C to defrost problem
I have a 2004 ford explorer and the a/c blows though the defrost only and I have read there might be a vacum problem but can't find the vacum hoses.
  #60
Old 11-27-2012, 10:11 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
yes, you have a vacuum problem. Read all of the posts. You can have a bad hose under the hood at the fire wall, at the vacuum accumulator, rotted hoses, the hose thru the dash, or a leak on the controller at the dash. Need to start narrowing it down. Pull a hose, check vacuum, suck on the hose and see if it leaks, etc.
Air conditioning blowing only thru defrost vents pcdocta Cooling, Heating, Ventilation & A/C 39 06-18-2016 08:13 AM
No air blowing from floor vents IIGood Explorer, Sport Trac, Mountaineer & Aviator 6 01-21-2016 07:12 PM
2006 Diesel heat& defrost problem cmlandscape 6.0L Power Stroke Diesel 2 07-14-2015 11:31 PM
Air Blowing through defrost vents only... jennshusbum 1999 - 2003 7.3L Power Stroke Diesel 8 07-26-2014 11:07 AM
Ac blows hot but defrost blows cold velocicurtis 2004 - 2008 F150 2 07-17-2014 11:39 PM
Tags
2001, 2003, ac, air, blows, conditioner, conditioning, default, defraust, defrost, defroster, f150, ford, truck, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
