electric brake controller plug location - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-29-2009, 08:08 PM
murraycookies murraycookies is offline
murraycookies is starting off with a positive reputation.
I,m renting a 2008 superduty to pull a trailer and i can't find the plug for the brake controller. Where is it located and is it round or square. I think the trailer dealer gave me the wrong plug. He said the 05 plug fromredline prodigy connector would work.
Old 07-29-2009, 09:37 PM
Destroya Destroya is offline
Destroya is starting off with a positive reputation.
Its below the ESOF switch, under the dash. You have to remove the panel just under the steering wheel and the plug will be to the right, near the metal framework.
Old 07-29-2009, 09:47 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
And it's usually hidden and taped/tied to the frame work. The plug should be a rectangle from the late 90s to at least the 08 body change, and I'd suspect for a few more years unless it has the tow command already (which has some other electrical components.)
Old 07-29-2009, 10:01 PM
2008 f250 brake controller wiring
I bought the wrong plug for my controller. It has four wires and the plug has eight wires going in to it. Does anyone know where the four wires from the controller go to on the plug so i can splice into them?
Old 07-30-2009, 06:51 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
There is some wrong info on this thread...
The TBC plug for the the 2008 will be attached to the back of the left coinholder below the HVAC controls (Where the Factory ITCB goes).
The plug from the truck will have a whole mess of wires going in, but most of them are for the factory ITBC. There are only 4 wires necessary to run an aftermarket controller, so the adapter will only have 4 wires, blunt cut and ready to crimp onto the TBC.
Old 08-06-2009, 08:55 AM
stupidjet stupidjet is offline
stupidjet is new and has a neutral reputation at this point.
what about before 2008??
Old 08-06-2009, 07:10 PM
TexasRebel's Avatar
before 2008 it should be in about the same area, but may not be nicely plugged into a panel...
post #2 would probably be a good place to start
trailer, no brakes, no lights, nothing old farm truck Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 12 04-12-2016 10:18 PM
E350 prewired for trailer brake controller? Killer RC 1968-2013 Full Size Vans 38 09-08-2015 11:19 AM
trailer brake wiring Crazyotto1 1999 - 2003 7.3L Power Stroke Diesel 2 12-28-2013 10:08 AM
1997 F-250 HD Trailer Brake connector location? bigsbetter11 1987 - 1996 F150 & Larger F-Series Trucks 3 05-22-2013 08:04 AM
2012 F150 Eco boost trailer brakes fatforty 2009 - 2014 F150 6 08-10-2012 07:47 AM
Tags
2001, 2002, 2004, 250, brake, controller, dash, electric, f250, f350, find, ford, location, plug, trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
