Parts diagram, front axle? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-29-2009, 07:55 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Since I have a job again and I have to do some commuting, I want to do some work to the hubs. But while I have the hubs out and I have 75k on the OE parts, I'd do some other work. Anyone have a parts or exploded view diagram of the front axle. I'm thinking hub bearing assy, the two orings per side, upper/lower ball joints, axle seal and greasing the needle bearing. Any other suggestions of parts to be dealt with while things are a part?
Old 07-29-2009, 08:12 PM
ReAX's Avatar
While I'm at it, anyone have some dimensions on the bearing assy grease adapter?
Old 07-29-2009, 08:32 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Don't like Guzzle's write ups?
http://www.guzzle7pt3.com/nblube.php
http://www.guzzle7pt3.com/allube.php
http://www.guzzle7pt3.com/transfer.php
http://www.guzzle7pt3.com/fdiff.php
If you still want the exploded view let me know and I'll see what I can dig up.
Old 07-29-2009, 09:34 PM
ReAX's Avatar
I have better access to aftermarket parts and I was going to follow the needle bearing and hub lube when I got the parts. Transfer case was simple, and I have a mag hytech on the rear, and they were done with RP at 60k miles.
Exploded would still be helpful so I can sit at a computer and work up a parts list/price. I know dorman has the one (I think it's the hub) seal, but I haven't found the yellow in aftermarket yet, ball joints are simple Moog, TRW, Dana. National should have the axle seal, but I don't know what else I want to tackle so I don't have to pull it apart again.
Old 07-29-2009, 10:16 PM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
Old 07-29-2009, 10:17 PM
Furian's Avatar
Old 07-29-2009, 10:18 PM
Furian's Avatar
Old 07-29-2009, 10:20 PM
Furian's Avatar
Old 07-29-2009, 10:35 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
There's some debate on how necessary this is, but while you're all the way in there, you could also replace the axle u-joints. Mine still felt decent but I replaced them while I was in there anyway.
Old 06-23-2012, 06:07 PM
awwwsnaps awwwsnaps is offline
awwwsnaps is starting off with a positive reputation.
Regarding Hubs
When I drive, my front passenger side hub clicks and groans in protest to the simple load of driving. I slipped the transfer case into neutral (so i could rock it back and forth from underneath) and found that at certain points the assembly doesn't turn with the tire like the drivers side does, then it will click and start turning. What could be the cause of this?
Old 06-23-2012, 08:51 PM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
Here is a PDF File that I put together for you. You will have to download it to see it. I wasn't sure which front axle you have, so they are both on here.
Old 06-23-2012, 08:59 PM
brd7666's Avatar
I just realized this thread is three years old. HAHAHA
Old 07-30-2012, 12:25 AM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Brd7666,
Thanks for posting that file. I have an F250 to pick up
that is missing the drivers side hub,spindle and arms.
I needed to see what should be under there before I
go see it the first time. I will be loading it on a tilt bed
trailer and towing it home. I was worried on just how I can
make something to load it with.
Thanks
Sean
Old 11-02-2012, 07:23 PM
NE14SAND's Avatar
NE14SAND NE14SAND is offline
NE14SAND is starting off with a positive reputation.
THANKS FOR LINKS!!!
Rebuilding Front Hub on Dana 60 terrylamar 1994.5 - 1997 7.3L Power Stroke Diesel 6 03-27-2016 10:22 PM
Front hub issues, ESOF still works DidieX Excursion - King of SUVs 8 10-07-2015 12:27 AM
4 WD front end questions JRS2 1987 - 1996 F150 & Larger F-Series Trucks 4 04-16-2015 09:10 PM
2001 4x4 front axle issues ghig1967 1999 - 2003 7.3L Power Stroke Diesel 14 03-18-2015 07:38 PM
2003 Ford F350 Truck 4WD Front Wheel Bearing & Hub Assembly Pair for Models with 2 Wheel ABS & Singl 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 01-03-2014 03:44 PM
Tags
2000, 250, 4x4, axle, diagram, diagrams, duty, exploded, f250, ford, front, parts, super, truck, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
