1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
1998 Expedition Oxygen Sensor
Old 11-18-2002, 11:05 AM
jworthington's Avatar
jworthington
jworthington is offline
[updated:LAST EDITED ON 18-Nov-02 AT 12:27 PM (EST)]I have a 1998 Expedition. My check engine light just came on so I took it to the dealer. They informed me that the air filter was torn, which lead the the burn out the Mass Air Flow sensor. So they were going to replace everything above and clean out the entire intake systems for $700.00.
Is this an absolute rip off or does this sound about right? I've checked the parts list and it comes out less than $200.
I'm new to Fords and the forum, any help would be appreciated.
Old 11-19-2002, 07:06 AM
1999XLT's Avatar
1999XLT
1999XLT is offline
That is a "HOSE" job if I have ever seen one. That price is absolutely OUTRAGEOUS. You could replace everything with better aftermarket parts, and clean out the intake system yourself for a helluva lot less than $700.00. It all depends on your mechanical ability, But what you described can be done with simple hand tools in about 15-20 minutes. Cleaning the intake is simple with modern chemical agents. Check previous posts around the forum to see what peoples preferences are as to cleaners. But I would definetly do it myself. Good luck.
Old 12-10-2002, 10:34 AM
kperry's Avatar
kperry
kperry is offline
I have same year, same light code. THe Autozone man said it may be as simple is checking the wire to the sensor on number 1 cylinder. If wire is ok, then cleaning of sensor may get rid of that light.
Old 12-19-2002, 03:39 PM
hensonjames2002's Avatar
hensonjames2002
hensonjames2002 is offline
hello, just to start, my mass airflow sensor went out and ford wanted to charge me two hour labor, ($140labor & $280 part). i decided to do it myself,(i am not that mechanical type) it took me 5 min at the most. if you can change your air filter you can change your mass airflow sensor. any question i will be glad to help.
jim
1998 expy, 4.6, 2wd
k&n system, air intake chip.
Old 12-19-2002, 04:19 PM
LightMyCigar's Avatar
LightMyCigar
LightMyCigar is offline
Atom Miller
New Member Introductions
06-08-2016 08:09 PM
dhenthorn
06-28-2011 06:07 PM
elpadrino13
11-20-2010 06:14 PM
cr8zyjoker
10-05-2006 12:20 AM
ripcurl94
04-18-2006 09:58 AM
Quick Reply: 1998 Expedition Oxygen Sensor
