1998 Expedition Oxygen Sensor - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 11-18-2002, 12:05 PM
jworthington jworthington is offline
jworthington is starting off with a positive reputation.
[updated:LAST EDITED ON 18-Nov-02 AT 12:27 PM (EST)]I have a 1998 Expedition. My check engine light just came on so I took it to the dealer. They informed me that the air filter was torn, which lead the the burn out the Mass Air Flow sensor. So they were going to replace everything above and clean out the entire intake systems for $700.00.
Is this an absolute rip off or does this sound about right? I've checked the parts list and it comes out less than $200.
I'm new to Fords and the forum, any help would be appreciated.
Old 11-19-2002, 08:06 AM
1999XLT's Avatar
1999XLT 1999XLT is offline
1999XLT is starting off with a positive reputation.
That is a "HOSE" job if I have ever seen one. That price is absolutely OUTRAGEOUS. You could replace everything with better aftermarket parts, and clean out the intake system yourself for a helluva lot less than $700.00. It all depends on your mechanical ability, But what you described can be done with simple hand tools in about 15-20 minutes. Cleaning the intake is simple with modern chemical agents. Check previous posts around the forum to see what peoples preferences are as to cleaners. But I would definetly do it myself. Good luck.
Old 12-10-2002, 11:34 AM
kperry kperry is offline
kperry is starting off with a positive reputation.
I have same year, same light code. THe Autozone man said it may be as simple is checking the wire to the sensor on number 1 cylinder. If wire is ok, then cleaning of sensor may get rid of that light.
Old 12-19-2002, 04:39 PM
hensonjames2002 hensonjames2002 is offline
hensonjames2002 is starting off with a positive reputation.
hello, just to start, my mass airflow sensor went out and ford wanted to charge me two hour labor, ($140labor & $280 part). i decided to do it myself,(i am not that mechanical type) it took me 5 min at the most. if you can change your air filter you can change your mass airflow sensor. any question i will be glad to help.
jim
1998 expy, 4.6, 2wd
k&n system, air intake chip.
Old 12-19-2002, 05:19 PM
LightMyCigar LightMyCigar is offline
LightMyCigar is starting off with a positive reputation.
Engine Swap Help E150 4.6L CANIAM27 Modular V8 (4.6L, 5.4L) 0 07-01-2015 06:28 PM
Running Boards 1998 Expedition lswinnie Electrical Systems/Wiring 4 01-20-2015 11:50 AM
1998 expedition 5.4 rough idle 2001f1505.4 Expedition & Navigator 3 03-31-2014 10:54 AM
1998 expedition EB air condition stuck on COLD! elvaktran Expedition & Navigator 0 01-25-2014 01:52 PM
A4wd light flashing on 1998 Expy dakota23 Expedition & Navigator 11 11-19-2013 12:05 AM
Tags
0xygen, 1998, expedition, hose, mass, oxygen, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
