Driving on beach sand...
Didn't want to hijack a thread so started my own that could be abused..
Going on vacation in August and plan to go drive on some very soft, possibly churned up sand to get to a good fishing spot. Not really sure about technique driving on stuff like this other than keep it in 4wd.. assuming 4LO? Tires are not really made for this kind of driving (big tread) but are not highway tires..kinda of an all-terrain type of tire. Any suggestions would be great.. I plan on having a shovel..my dad has a winch on his truck so it shouldn't be too bad.
B.
B.
air down is the biggest thing that will help besides having it in 4x4 so you don't dig.
So you need to provision for airing the tires up and down. How much air should you run, that I am not sure but I would guess somewhere around 20 psi.
Some others who have run in the sand quite a bit will chime in soon with some better advice.
If the sand is loose and soft like you say it is, do yourself a favor and it hit as fast as possible in 4wd hi. Don't stop until you get to hard pack. These big trucks suck in the sand, yes you can do it, people do all the time, but in the loose stuff, it's going to get stuck if you stop.
Bring a shovel, a tow strap, and stick close to your dads truck. Don't try to gas your way out of anything if you start spinning all your wheels. Stop, get out, and dig. Do not sink that thing up to the axles.
driving on beach
I have been driving on the beach for 25 years in Cape Hatteras. The key is to drop the tire pressure to 20psi. Never try to speed your way through. If you feel like the truck keeps bogging down, drop the pressure to 18psi. I have never been stuck by following this rule. Many locals in Hatteras leave their tires ar 20psi year round. When I am there for a week at a time, I leave it at 20psi and drive slow around town. Stop into the local fishing store and get a little toy that screws on to the valve that automatically reduces the air to 20psi. They work great and save the back! Have fun.
you will also need a small peice of plywood (3ft x 3ft) in case you need to use the jack. If you don't have plywood and you are dug in deep, you will have a tough time.
Also, a good tow chain or tow straps would help. There probably won't be many vehicles that could pull you out but it's worth having.
Another thing that might help is a piece of chain link fence about 12 ft long and 2 or 3 ft wide and a stake to hold it in place. When you get stuck start it under the tire so that the lugs just start to grip the fence then pull the fence out and stake it in the sand this will let you climb out of the sand and up on top so you can go on your way.
The little cheapie ones work great for car tires - and while they're capable of making enough pressure... our tires have so much volume that they tend to burn out before the tire gets filled from such a low pressure. (Had this happen a couple days ago actually - melted the plastic gears and slagged the little motor)
If you're not going to run a hard line with a plug specifically for running a compressor - I'd suggest one that clips directly to the battery terminals. Most of the bigger auto parts stores have them, as well as being able to find them on line.
Other suggestions: spent the extra money to put a quick connect fitting on the end of the hose.
This way you can run a regular tire fill / gauge combo like you'd see at a gas station for topping tires off and still switch out for other fittings. Another favorite is to have is the little "old school" screw on tire filler. The quick release fitting will make it easy to spin on, and it'll save you having to sit stooped over your tire while it fills up. (12v compressors take time...) If it's a better one - you can even set the regulator to the pressure you want and just let it run for a bit while you do something else. (A lot of guys are fond of taking this time to drink a beer or start a conversation beginning with "My truck is better than..." or "My air compressor is better than....") Again - you can get by without it, but it's a nice convenience thing.
Airing a tire back up is more fun when you can sit back and finish your beer while admiring your own handy work.
