Need a new ZF extension housing
I recently got an entire F350 just like mine for a great deal. It has the 460 ZF5 I've been looking for but there is one major problem. The trans mounts on the extension housing totally broke off. Probably cause one of the motor mounts was completely gone. Anyway, it's a Zf-42, and I'm wondering what other extension housings will be the same. Do I need a 460/diesel one or will any small block version work too? It's a shame because the rest of the trans is in great shape. It's 4x4. Thanks.
I was quoted about $300. for the extension housing and about $900. in labor--I was considering doing it myself but not after screwing with an injured shoulder for 8 months. So far, the welds are holding....
Or, to put it more succinctly--SUBSCRIBED!
If these are so weak, does anyone think it would be a good idea to just come fabricate a new mounting system using the tcase mounting flange and bolts? It doesn't look like it would be all too hard and from the research I'm doing it looks like it could be stronger than the stock setup anyways.
Both the S5-42 and S5-47 were available with wide and close ratios. The gas models should have the wide ratio, and the diesels could have either.
The part number for the extension housing should be listed in one of the documents found here: http://www.zf.com/na/content/en/impo...t_Catalog.html
OJs DNA
1999 to 2016 Super Duty
01-07-2022 08:11 AM
CantAffordAToyota
04-18-2017 04:36 AM
Brett1322
12-13-2016 10:35 PM
Nicholas Fluhart
10-05-2016 09:25 AM
