Nozzles???
If you're blaster is a cabinet rather that a pot, you might look to see if you've got a hole worn in the rubber hose down near where it connects to the metal pick up line. That happened to me. I had tons of air but no media.
Another possibility is that you've gotten ahold of the heavier of the two Black Beauty products. I had that too and couldn't get it to flow very well through my cabinet. But I think my problem was that it was too big for the pick up, not the nozzle. I switched to the lighter mix and problem was fixed. Stu
Blasted...
I got a "good" deal on this media blaster from Eastwood
last Fall...only $121.00 to my front porch...not bad...I thought...
But...there is always a "butt"...EVERY time I hit the deadman
throttle...it jams...
Shut everything down...unscrew the nozzle & sure as day...there
is a peice of BB sittin' there too large to pass through the
ceramic......
Man (& Gal's) this is stupid...
Of course Eastwoods suggestion was to "find an alternative media"...
I'm sure you can imagine MY reply...
I stumped...I've looked everywhere (I think) & I cannot find
ANYTHING larger than a 5.0mm ceramic/rubber blast nozzle...
Any ideas...maybe a different blast-gun, or handle, or....
deadmans-whatever-it-is???
-Thanks...
ceramic......
-Thanks...
I can't help with the nozzle but I am curious, what are you blasting? I use Black Beauty in my siphon system because it's weak and the additional aggressiveness of the Black Beauty kind of helps. I have blasted small to rather large parts, anything I can fit into my 6 foot cube blasting cabinet. I have also blasted a few pieces of sheet metal without a problem with warpage but I don't think I would blast sheet metal with Black Beauty with a pressurized system like the one you have. I would use a milder media for that. Maybe I'd use it on mechanical parts like suspension parts or something that can more safely handle the aggressiveness and heat generated by a pressure system.
blasting blaster...
Trying to cleanup a 9" rear-end housing...I got beat-up pretty bad & I ran
out of 4" wire-cups..they didn't do too much anyway & my poor ol'
grinder......
Anyway...I was gonna do the '56 rear drums & some other stuff...haven't
even thought about gettin' to any of the nitty OR the gritty yet...
Yeesch...
grinder......
Yeesch...
Homemade Throttle...
I JUST emptied the tank to make sure the media IS dry 'cause the
SUN finally appeared...haven't seen THAT in DAYS...
While the BB is sun-bathin' I'll run some air-only thru the tank and
make sure there are no gremlins in there alsoand everything is nice
and moisture-free...
Good thing the in-laws hardware is only about 1 mile away......
THANKS......I'll keep "you'se" updated with that idea...as well as
with the rest of the groups suggestions...
I'm gonna get some type of screen set-up also...
Wow...I thought I only had to mow the lawn and
take out the trash today......
I think the black beauty is same as coal slag and it is difficult to blast with. I too got fed up with nozzles on my pressurized pot and found air hose disconnects are a cheap short term nozzle. Threaded fitting on the end and about two inch long "nozzle" with a quarter inch hole worked pretty well. They don't last long but better than shutting everything down to unplug the valve. Will get you by in a pinch to finish a small project.
