Basically I am using this forum as a testing ground trying to find out what is up with my signature but thought I would post something relevant here just because I think it's cool.
No I actually made the air cleaner from my original and one from the junkyard. I am in the process of making dual "ram air" intakes to match the factory style ones that come out the radiator support.
Yea the filter is now a Motorcraft that Fram was a 5Quart and a Filter deal, figured I'd run it for a day or two after the rebuild and then put on a good one.
That's a good job on that air cleaner, it's looks factory. I've got a single snorkle out in the shed same color as that. I got it in a junkyard off of another truck. But that looks really good.
It was 3 on the tree when I got her but I have put in a floor shifter... No one ever rides in the middle any way.
I used to use Fram filters all the time just because I like the color Orange but after cutting a few filters open I realized that Fram is not exactly what I would call quality. I will use them after a rebuild to get anything that may have gotten into the block out but replace them shortly after. I do that regardless of what type of filter it is.
