Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 07-28-2009, 12:41 AM
threefiftyone's Avatar
threefiftyone threefiftyone is offline
1996 Ford F-350
threefiftyone is starting off with a positive reputation.
Spare Wheel
My wife go a flat tire last week and had to put the spare on (of course). The low pressure indicator light came on as it should do, and read something like "low tire pressure in fault." The next morning she verified the pressures in all tires and continued on her way. The light remained on, and has been on this past week since she got the flat. (She is out of state, so I can't help her) The psi in the spare tire is still ok, but he light is still on. Apparently Les Schwab indicated the tire cannot be repaired. Because she's in a unrustworthy environment, I told her to just leave the spare (tire and wheel) on for now and bring the flat mounted on the alum rim home. I want to see it for myself - hell it's just a nail puncture.
Is the light still on because of the steel wheel? We were kind of thinking that there may be a sensor built into the aluminum wheel that tells the cpu it's ok. Everything else checks out. Is this accurate or coincidence? Do we just need to have the code reset?
Now that I'm thinking about it more, that doesn't make sense. What happens when you get aftermarket wheels? Nothing
>>kicking myself for not getting good repair manuals yet<<
Thanks
__________________
Don't ya just hate those a_$_$_h_o_l_e_s who post just to increase their numbers but actually have nothing meaningful or relevant to say? I DO. So unless you're going to make a difference, just don't even bother. Everyone else will see that too. Have a good day
  #2 (permalink)
Old 07-28-2009, 04:01 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
the four "normal" wheels have a TPMS sensor mounted in them.
The Spare does not.
So until you get the flat wheel fixed and aired up properly, it will show the low tire warning light on the dash/message center.
As for the tire be unrepairable, it may have the nail in the sidewall or the part where the tread and sidewall meet. If so, no respectable tire shop will repair it. It's an issue of liability.
I had the same problem at Discount Tire. One of my $200 tires for my Mustang GT had gotten a nail in the transition area. They refused to patch it. I ended up buying 2 new tires about 1" wider overall.
once I thought about it...their reasoning made sense.
btw, eBay is awesome for those repair manuals. I picked up a 2008-2009 and a 2009-2010 Ford OEM DVD Repair Manual for $32 shipped.
These things rock. I had a 2005-2006 one for my F-150
You can search for what you are after, and it gives you a very easy navigation menu to schematics, wire diagrams, part lists...lots of goodies that a generic Chilton/Haynes won't
Here are a few examples. I recommend you don't pay more than $25 shipped for one. These people are getting them for free in most cases.
also make sure it is a real OEM DVD. some sellers are selling access to an internet site...which is fraud and a rip-off
http://cgi.ebay.com/FORD-2007-2008-S...d=p3286.c0.m14
http://cgi.ebay.com/ebaymotors/Ford-...sQ5fLiterature
http://cgi.ebay.com/FORD-2008-2009-S...d=p3286.c0.m14
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 07-28-2009, 11:17 AM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
I agree with the manual. Very cool.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #4 (permalink)
Old 07-28-2009, 05:55 PM
IQ9 IQ9 is offline
IQ9 is starting off with a positive reputation.
Thanks for the links! It will help out when I get home to buy.
__________________
White Sand 08 Expy EL Limited 4x4 with everything but the power running boards & trip tunes.
  #5 (permalink)
Old 07-28-2009, 10:55 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
There is no TPMS sensor on your spare. Only on the 4 wheels that come on the truck from the factory. If you bought a set of aftermarket wheels, you would either have to swap over the sensors from your stock wheels, which includes buying new bands to mount them to the new aftermarkets, or buy new sensors and bands to be mounted on the new aftermarkets. A set of sensors and bands to mount on new aftermarket wheels runs approx. $325 or so depending on where you get them.
  #6 (permalink)
Old 07-29-2009, 12:11 AM
1996 Ford F-350
-OR- Just say the hell with the whole TPMS sensor as a whole and just reset the code all the time.....right? LOL
Actually I came across a set of wheel and tires off an '03 Navigator. Does anyone know if that would be compatible with the existing TPMS? Did they offer this feature back then? I've been trying to locate an answer to that question but with little luck.
__________________
  #7 (permalink)
Old 07-29-2009, 06:03 AM
shorebird's Avatar
shorebird shorebird is online now
Wage Slave
2008 Ford F-150
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
No TPMS on the '03s. TPMS indicator can not be reset until there are 4 properly pressurized sensors on the vehicle. TPMS Phase-in started in October 2005 at 20%, and reached 100% for models produced after September 2007.
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #8 (permalink)
Old 07-29-2009, 08:20 AM
04markIII's Avatar
04markIII 04markIII is offline
04markIII is starting off with a positive reputation.
Quote:
i beg to differ. my 03 expedition had factory tpms. i also installed a sensor in the spare wheel as well, which it does read and give faults for if need be.
__________________
2003 Expedition: 5.4L, Harley supercharger, 4lb lower pulley, c&l plenum, k&n panel filter, LFP SBTB, FTSP, removed front cats, Magnaflow 3" catback, Bilsteins, Eclipse AVN-5510, white face gauges, cobalt c2 boost gauge, 331 rwhp, 432 rwtq (dynoe'd w/20's, 17's back on now)
Tags
09, 2007, 2010, expedition, f150, ford, monitoring, mustangtpms, oem, pressure, problemsspare, reset, sensor, spare, system, tire, tpms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
