Tool Kit Missing?
Tool Kit Missing?
Just got my 2009 F150 XLT - really enjoying the truck. I was looking for my fuel funnel that goes into the capless filler neck, and the manual says its under the rear seat in the compartment where the tool kit is. Well I found the funnel, but there's nothing else in that space.
Did they forget to give me something?
This is from the owners manual of my new Escape. The info would be the same except for the storage location of the funnel.
Refilling with a portable fuel container
With the Easy Fuel™ “no cap” fuel system, use the following directions
when filling from a portable fuel container:
WARNING:
Do not insert the nozzle of portable fuel containers
or aftermarket funnels into the Easy Fuel™ system. This could
damage the fuel system and its seal, and may cause fuel to run onto
the ground instead of filling the tank, which could result in serious
personal injury.
personal injury.
WARNING:
Do not try to pry open or push open the Easy
Fuel™ system with foreign objects. This could damage the fuel
system and its seal and cause injury to you or others.
When filling the vehicle’s fuel tank from a portable fuel container, use the
funnel included with the vehicle.
1. Locate the white plastic funnel. It
is attached to the inside of the rear
passenger side cargo compartment
access door.
2. Slowly insert the funnel into the
Easy Fuel™ system.
access door.
Easy Fuel™ system.
3. Fill the vehicle with fuel from the portable fuel container.
4. When done, clean the funnel or properly dispose of it. Extra funnels
can be purchased from your authorized dealer if you choose to dispose
of the funnel.
of the funnel.
Do not use aftermarket funnels; they will not work with
the Easy Fuel™ system and can damage it. The included funnel has
been specially designed to work safely with your vehicle.the Easy Fuel™ system and can damage it. The included funnel has
