Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 07-27-2009, 05:38 PM
jtm8571 jtm8571 is offline
Garage is empty, add now
jtm8571 is starting off with a positive reputation.
Question converting dual tank to single tank
I have a 94 f-150 single cab, it has the 302 with the dual tank set up, my back tank seems to be pumping fuel into my front tank as well as the fuel rail, after about 10 mintues it will have enough pressure to start pushing fuel passed the gas cap and out the side of the truck. not vapors, actually liquid fuel. i looked into it, and know that the switching valve could be not switching entirely, and that the one way check valves in the fuel lines could be shot. the problem is im on a students budget, so i dont have the money to spend, but i have the knowledge. i was wanting to convert it from a dual tank to a single tank system, does anyone know where i could find the parts or any instruction to somewhat follow? this is my daily driver, and i cant have it down for more then a night.
thanks for any help.
Jeremy
P.S. i can hear both front and back pumps turn on when i cycle the key.
  #2 (permalink)
Old 07-27-2009, 05:42 PM
Neptoess Neptoess is offline
Neptoess is starting off with a positive reputation.
you could just pull the relay for the rear fuel pump, and it won't pump anymore. Or you could bypass the switching valve entirely and just hook your front pump directly to your fuel rail
__________________
1995 F-150 EB 302/4R70W rc lb 2wd 3.55s
-Sony Head Unit controlling 30 GB iPod
-Kenwood KAC-6202 200W RMS@2 Ohms into:
-Polk Audio 55W 6.5" front speakers
-Pioneer 50W 6x8 rears
-Kenwood KAC-6104D 300W RMS@2 Ohms into:
-Alpine Type S 10" Subwoofer mounted behind drivers seat
  #3 (permalink)
Old 07-27-2009, 05:43 PM
bren_tx bren_tx is offline
bren_tx is starting off with a positive reputation.
i have a similar problem. if i have the switch on rear it will over flow the front tank. but if i keep the switch on front, it will pump out of the front tank and somehow the rear will slowly front tank, so its almost like having a single tank and i really dont have any problems that way. its always funny to park the truck with a 1/4 tank of fuel in the front and then come out the next morning and its almost full
  #4 (permalink)
Old 07-27-2009, 05:44 PM
sounds like you've got some check valve problems bren
__________________
  #5 (permalink)
Old 07-27-2009, 05:48 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Yeah you have the fuel tansfer problem. Your truck does not have the a switching valve just a pump module inside each tank. To disable a tank disconnect the power at the tank so you dont accidentally empty the contents on the ground and create a fire hazard, and find some studs like those in the pic below. A couple minutes with a hacksaw and grinder and you can turn them into plugs for the fuel lines, note you will need 2 different size studs for the send and return lines. Don't simply connect the 2 ends together or you'll create a fuel delivery problem with the other tank.
Click the image to open in full size.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1990 2.3L 5-sp Ranger 3.08, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
  #6 (permalink)
Old 07-27-2009, 05:53 PM
conanski's idea is much more sound than mine. stick with his, i shoulda looked in my chiltons first to realize there is no selector valve
__________________
  #7 (permalink)
Old 07-27-2009, 11:24 PM
where are the check valves? are they in the diverter valve?
  #8 (permalink)
Old 07-27-2009, 11:26 PM
on tank filling the other tank
__________________
  #9 (permalink)
Old 07-28-2009, 12:00 AM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
1975 Ford F-150
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
http://www.stangler.com/motorsports/...alve/index.htm
Wow, cool old post by "Mustang 5.0" huh? :)
That thing sure seems overly complicated for what it does. :/
And this by Conanski...
http://farm4.static.flickr.com/3023/...f82e2acd71.jpg
Looks like something a guy should just make and have in the tool box, to me! :)
Alvin in AZ
Tags
1990, 90, 94, converting, dual, electric, empties, f150, ford, front, overflow, pumps, rear, single, tank, tanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
