What year for OBD1 to OBD2 - Ford Truck Enthusiasts Forums
Old 07-27-2009, 10:31 AM
frankyford frankyford is offline
frankyford is starting off with a positive reputation.
What was the actual year they started putting OBD2's in the F-150's? My 95 puts out 2 digit codes and a guy I just got off the phone with said that's impossible because my truck has the OBD2 in it not the OBD1. I was told and the code reader for my truck is for a OBD1. Is there a way to truly tell.
Old 07-27-2009, 10:43 AM
alxsnmr alxsnmr is offline
alxsnmr is gaining momentum as a positive member of FTE.
1996 was the year mandated for all vehicles to have OBDII except for vehicles above 8300 GVWR (I think that is right). I would have thought your truck would have 3 digit output, but someone said here that it depends on your transmission, i.e. E4OD, AOD-E, 4R70W did have 3 digit codes manuals had 2 digit.
Old 07-27-2009, 10:48 AM
Mine is an auto with a 302, on my code scanner it's putting out 2 digit codes. Even when I took it to my brother-in-law at the Ford dealership it came up wityh a 2 digit code. I don't know which tranny I have, it's either an AOD-E or an 4R70W. It's hard to tell cause both had a 14 bolt pattern.
Old 07-27-2009, 10:51 AM
AOD-E and 4R70W are essentially the same transmission on the outside. The internals are pretty well the same except for the gearing, with a revision in the late 1990's. I believe that the trucks received the 4R70W and cars the AOD-E.
Old 07-27-2009, 10:54 AM
Yeah, the AOD-E is a little smaller than the 4R70W, without putting together side by side I think it'd be hard to tell one from the other. Someone else may know different.
Old 07-27-2009, 11:48 AM
96F350Beast 96F350Beast is offline
96F350Beast is starting off with a positive reputation.
Quote:
My 96 F350 has OBDI - Man date 05/96
Old 07-27-2009, 11:55 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
All light trucks under 8500lb GVWR were OBD-2 in 1996, but trucks over 8500lb didn't get it until the '98 model year.
Old 07-27-2009, 12:02 PM
f250ssd f250ssd is offline
f250ssd is starting off with a positive reputation.
Wouldn't it be possible to tell by the test connector?
Old 07-27-2009, 12:05 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
It's got nothing to do with the transmission.
If the test connector is under the hood behind the airbox it's OBD-I. If the connector is under the dash it's OBD-II. The switchover to three-digit codes was around the 90-92 time frame. A 1995 F-150 will be OBD-I and will give three digit codes.
Old 07-27-2009, 02:53 PM
I guess I'm going to have to recheck my scanner again, cause mine's putting out 2 digit codes. It'll flash (beep beep [short pause] beep beep) long pause then put out the next code.
Old 07-27-2009, 02:55 PM
andym's Avatar
Unless someone swapped the PCM out with an older one (anything's possible if you're not the original owner) then it should definitely be three-digit codes.
Old 07-27-2009, 03:03 PM
I bought it off my neighbor and he told me that he had to get the computer rebuilt a couple of years ago. Maybe when they programmed it, they progammed it for 2 digit codes. If that makes sense.
Old 07-27-2009, 03:08 PM
andym's Avatar
You can't program a PCM (well, you can, but you can't change the codes it puts out, at least not very easily). But if he had to get it "rebuilt" it really means he had to get it replaced, and the replacement obviously gives you two digit codes.
obd1 or obd2?/sd or maf xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 18 08-06-2015 02:03 AM
obd1 or obd2 Crewcabber 1987 - 1996 F150 & Larger F-Series Trucks 12 04-16-2014 08:24 PM
Obd1 Or Obd2 ? johnanderson 1987 - 1996 F150 & Larger F-Series Trucks 12 05-09-2013 01:58 AM
obd1 or obd2 F350Kid238 1987 - 1996 F150 & Larger F-Series Trucks 9 12-17-2011 06:08 AM
maybe adumb question kalawikimaui 1987 - 1996 F150 & Larger F-Series Trucks 6 04-24-2011 11:01 PM
Tags
250, 31, 94, 95, codes, conversion, f150, ford, obd, obd1, obd2, obdii, truck, vehicles, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
