Rislone engine treatment - Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Old 09-21-2002, 05:58 PM
poopey poopey is offline
poopey is starting off with a positive reputation.
Does anybody here use a quart of Rislone at each oil change to minimize deposits? I know they recommend against using additives,but Rislone sounds like one of the safest on the market.Its probably safer than MMO as far as not affecting viscosity,right?
Old 09-22-2002, 12:35 AM
samhihn samhihn is offline
samhihn is starting off with a positive reputation.
IMHO if the manufacturers and oil companies thought products like Rislone were so great they would already be using them or recomending their use with their products.
Old 09-23-2002, 10:54 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Post Rislone engine treatment
Rislone has been around not quite as long as MMO and has a loyal following. I used it 30 years ago as an engine flush. Such additives are no longer needed with modern oils and cleaner-running computerized engines.
Jim
Old 09-25-2002, 10:46 PM
4x4x4x4 4x4x4x4 is offline
4x4x4x4 is starting off with a positive reputation.
Rislone is great for cleaning up a dirty,not filthy,engine.It is also good for helping free up lifters that are plugged and don't want to pump up.It should be used only as needed and not part of a regular oil change.
My .02 worth.
Old 10-14-2002, 07:24 PM
Pheonix BlackWolf Pheonix BlackWolf is offline
Pheonix BlackWolf is starting off with a positive reputation.
Old 10-16-2002, 08:44 AM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
I use a quart of Rislone at every oil change which is every 3000 miles maximum. I do this for all three vehicles (listed in gallery) and have been doing it since 1977 when I got my new '77 F100. I wouldn't hesitate to use it in the new Fords that recommend 5W-20 oil. The folks at Rislone say the base oil they use is about a 5w20/25 and that you can use up to 25% of the crankcase in Rislone. My last oil change on the F150 I put 4.5 qts oil and 1.5 qts Rislone. IMHO it is great stuff. I just put some in a little old fashioned oil can and am waiting for the next squeaky door hinge in my house to use it. I guess I am a Rislone nut.
INLINE SIX POWER! '95 F150 XL
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be time for automatics when you're old and unable."
Old 10-21-2002, 11:37 AM
BigMattXXL's Avatar
BigMattXXL BigMattXXL is offline
BigMattXXL is starting off with a positive reputation.
From all that I've heard about oil treatments, they seem to do more harm than good. The general consensus is that if you change your oil on time, you shouldn't need any engine flushes (until you start getting "up there" (75K miles) for a while. Like the other guy said, modoern oils and modern engines don't generate as much "crud" as they used to.
keep it simple; keep it running.
XXL
Old 12-07-2014, 10:34 AM
conservative_america conservative_america is offline
conservative_america is starting off with a positive reputation.
great stuff
In 1991 I bought a 1985 LTD, found it to be sludged up pretty bad, using mobil1 and rislone, sludge was gone in three oil changes. I've used it every oil change since, sold that car with over 300.000 miles on it in 2006
Rislone vs Lucas fearfactory Oil & Lubrication 40 08-30-2016 05:00 AM
ZDDP pony Modular V8 (4.6L, 5.4L) 7 09-21-2014 11:29 PM
RISLONE? 88rustyred Ford Inline Six, 200, 250, 4.9L / 300 1 07-17-2011 08:11 PM
Rislone engine treatment Talyn 1994.5 - 1997 7.3L Power Stroke Diesel 2 09-26-2010 02:11 PM
03 Escape coolant leak spdracer50 Escape & Escape Hybrid 4 07-19-2010 01:37 PM
Tags
3000, cleaner, engine, flush, flushing, ford, good, miles, mmo, oil, products, review, reviews, rislone, treatment
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
