Door pins
Old 07-26-2009, 08:34 PM
jefxxo's Avatar
jefxxo
jefxxo is offline
Door pins
Is there a how to on removing and replacing the door pins? My guess it to grind the top of the pin off.?.
Old 07-26-2009, 08:45 PM
1966Tbird's Avatar
1966Tbird
1966Tbird is offline
i need to do the same thing and will be very interested in learning the answer to this
my plan is to remove the door pins and put in quick release roll cage pins so i can run a set of tube doors and remove the doors quickly and put them on quickly
Old 07-27-2009, 09:16 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
You can get new door pins in the HELP section at Advance, Orielly, A'zone etc.
I did this on my driverside door a few years ago. If I remember right, what I did was cut the pin and tap it out. I'll have to ask my dad what we did. We might have drilled the head out.
The new pin is easy to install and has a clip on it.
The new pin kit looks like this.
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
Old 07-27-2009, 01:25 PM
straightsixer's Avatar
straightsixer
straightsixer is offline
i've done door pins before and mine just tapped out with a hammer. I needed to re-align my doors afterwards.
Old 07-27-2009, 02:51 PM
nnero's Avatar
nnero
nnero is offline
Replace as soon as you can to avoid damage to the hinges. The PO of my truck could not get in without leaning on the door and never replaced the pins. Now the hinges are bad too and I have reach my arm out and lift up on the door to close it.
Old 07-27-2009, 04:16 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Cut the center of the pin w a sawzall then take the two halves out. As mentioned earlier, advanced has pins and bushings in the HELP section
Old 07-27-2009, 05:50 PM
Wynn96's Avatar
Wynn96
Wynn96 is offline
I put in new pins and they lasted about 6 onths. Went to the junkyard and pulled good hinges off a different truck and haven't had a problem since. Have fun lining them up though. They are a PITA to get adjusted right, but that's how I'd do it. Just go pick up some off another truck that are in good shape. The pins I got were a total waste of time.
Old 07-28-2009, 07:46 PM
TexasGuy001
The HELP pins I got fixed it and its been great for several years. Did you replace the bushing too?
Old 07-28-2009, 08:15 PM
Diesel_Brad
Pins? wher did you get them? I have only seen pins sold w bushings
Old 07-28-2009, 09:41 PM
Wynn96's Avatar
Wynn96
Wynn96 is offline
I got them at the Help section of the auto store. They came with pins and bronze bushings. Never again. I could never get the bushings to seat right, and they popped out from time to time. Maybe I put them in wrong. But I do know that I haven't had any trouble whatsoever with the hinges I pulled off a junkyard truck.
Old 07-28-2009, 09:46 PM
Diesel_Brad
you have to drill the hinges to accept the bushings
Gwilkrrs
22
12-11-2023 02:38 PM
Aftrmidnite
1997 - 2003 F150
04-26-2017 04:25 PM
reg1952
01-08-2017 07:12 AM
chad77
01-31-2016 12:23 PM
Brandon_J
06-19-2001 05:26 AM
Quick Reply: Door pins
