How to remove fan shroud? - Ford Truck Enthusiasts Forums
Old 07-26-2009, 06:54 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
It looks like you have to cut the fan shroud to remove it. Or remove the engine from the truck!
Old 07-26-2009, 07:09 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
I have not done it, but I saved this awhile back:
Do not cut the shroud...
Drain a little coolant out to get the level below the radiator top tank.
Then disconnect the radiator hose and degas hose from the radiator and position them aside.
Remove the 2 8mm screws from the fan shroud.
Remove the 4 8mm screws on the radiator retaining brackets.
Rock the radiator forward to increase clearance for the fan shroud.
Push the fan shroud rearward and pull up.
Watch those two hose connections on the radiator!
The shroud will lift all the way off the vehicle.
Old 07-26-2009, 07:22 PM
KRDiesel's Avatar
ok thanks for the info.
Old 07-26-2009, 09:40 PM
KRDiesel's Avatar
That is for the front part, It looks like the back part you have to remove the fan.
Old 07-26-2009, 09:44 PM
jboczar jboczar is offline
jboczar has a good reputation on FTE.jboczar has a good reputation on FTE.
The other part is removed with the fan attached, there are 4 15mm bolts two up top and two at the bottom, then remove the fan using a air hammer or the special tool wrenches if you have them, then lift the stator and fan out together.
Old 07-26-2009, 10:45 PM
bismic's Avatar
KRDiesel -
Why are you removing the shroud??
(so far it sounds easier than pulling the engine :-) .....................)
Old 07-26-2009, 11:11 PM
KRDiesel's Avatar
I am trying to find a coolant leak.
I now think it is the short hose to the egr cooler, I am seeing it at both the front and back of the motor.
Old 07-26-2009, 11:20 PM
bismic's Avatar
This may help ..........
You dont need to remove turbo to change the EGR cooler hose. All you need to do is cut the hose in half, take the t 30 bolts out of the oil cooler were it attaches, and remove the cover assembly. Slide old hose off and slide new one on.
Old 07-26-2009, 11:23 PM
bismic's Avatar
Quote:
Can't "rep ya" again yet, maybe others will. Always good to have a Tech helping out!
I have heard you can get the fan removed w/ a 1 7/8 in wrench (and be sure to disconnect the fan wiring harness - I have heard of these things failing recently).
Another post on the shroud removal:
To remove the shroud without removing the fan (requires two small cuts):
http://www.thedieselgarage.com/forum...ad.php?t=73075
Old 07-26-2009, 11:58 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Quote:
Done ...
Old 07-28-2009, 03:03 AM
DryHeatDude03's Avatar
DryHeatDude03 DryHeatDude03 is offline
DryHeatDude03 is gaining momentum as a positive member of FTE.
Since you have an '03 6.0 you should have the orange cooler hose if it hasn't already been replaced. They are prone to leaking. Can you see coolant in the valley directly below the cooler.
Old 10-20-2012, 07:34 PM
rideraa rideraa is offline
rideraa is starting off with a positive reputation.
Smile
Old old thread, but it worked for me.
THANKS
2006 6.0 fan shroud removal question maxum96 6.0L Power Stroke Diesel 5 10-12-2016 10:03 PM
WANTED: Upper Removable Fan Shroud Restlesswildman WTB - Parts & other 0 11-05-2013 09:58 PM
Fan Shroud Removal karthauler 1999 to 2016 Super Duty 1 09-12-2010 05:45 PM
03 fan shroud removal M.Farragher 6.0L Power Stroke Diesel 4 04-14-2010 11:32 AM
Fan Shroud Removal kawa 1994.5 - 1997 7.3L Power Stroke Diesel 6 10-24-2007 02:04 AM
Tags
2003, 2004, 350, 60, 60l, cover, diesel, f250, fan, ford, power, remove, removing, shroud, stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
