EGR coolant bypass.
Old 07-26-2009, 05:52 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
Question EGR coolant bypass.
Any cheep EGR cooler coolant bypass ideas??
I know you cannot just block it off because of the oil cooler.
Old 07-26-2009, 06:24 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Received 3,371 Likes on 2,076 Posts
Got a TIG welder handy?
Old 07-26-2009, 07:29 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
Wish, need to get one someday.
I am guessing that is where the coolant leak is. hard to tell on this engine.
Old 07-26-2009, 07:44 PM
Maxium4x4's Avatar
Maxium4x4
Did you check the small hose coming off the cooler, they sometimes leak and you can't see it.
Old 07-26-2009, 08:05 PM
rob40cal's Avatar
rob40cal
rob40cal is offline
Ya just fixed mine this weekend. took it off and mig welded plugs in each end of it, no more leaks to intake. Cut scoop out of pipe and welded plug there also. cost me nothing but my time and gasket kit.
Rob
Old 07-26-2009, 08:32 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
Yea. Like I can see that small hose!!
Old 07-26-2009, 09:27 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
Old 07-26-2009, 10:17 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
Sweet. Know what my projext next weekend is.
Old 07-26-2009, 10:38 PM
bismic's Avatar
bismic
bismic is offline
Received 2,448 Likes on 1,696 Posts
Rob
Steve's is even easier - he does not have a scoop in the up-pipe.
I got a 2004 up-pipe for $50. I an having the recirculation flange welded up. I also have an old EGR valve that I am welding shut. My EGR system delete will be the up-pipe swap and the EGR "plug".
Old 07-27-2009, 12:08 PM
JIM_C's Avatar
JIM_C
JIM_C is offline
Mark, do you even need to mess with the EGR valve if you block the exhaust flow?
Old 07-27-2009, 01:27 PM
HeavyAssault's Avatar
HeavyAssault
HeavyAssault is offline
Depending on your model year you can: a) unplug the EGR with no issues or b) use a SCT with custom tunes to prevent the CEL or code.
Old 07-27-2009, 05:49 PM
bismic's Avatar
bismic
bismic is offline
I am also welding up an EGR valve to be cautious. Since I am not planning on removing the EGR cooler (or even welding it up), I wanted to be sure that an EGR cooler coolant leak would not get into the intake through a weak EGR valve (even if it were in the "commanded closed" position).
Old 07-28-2009, 08:16 AM
DSMMH's Avatar
DSMMH
DSMMH is offline
Mark.......after a discussion on another thread I tested the EGR valve spring on a spare EGR valve I had. I was surprised how easy it moved. When I did it before I thought it was hard to move. Must have done it backwards. Getting old sucks! So I removed the EGR valve and got some high temp epoxy. I put the epoxy on the end valve only and reinstalled. I thought that if I ever had to use the EGR valve again a heat gun or small torch would release the epoxy and a wire wheel would clean the residue off the valve and seat. Welding is kind of a permanent thing.
DSMMH
Old 07-28-2009, 08:38 AM
bismic's Avatar
bismic
bismic is offline
DSMMH - I appreciate the suggestions. I am not too worried about the EGR valve. It is an old style and a spare. I would not install it in the truck anyway. I will say that the friend who I asked to weld the valve is worried about warping it while welding. So I may be back to the epoxy idea. What type/brand of epoxy did you use?
Old 07-28-2009, 12:33 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
OK, it is the water pump. It was running to the back of the engine while I was driving.
Quick Reply: EGR coolant bypass.
