1993 ford lightning - Ford Truck Enthusiasts Forums
1993 ford lightning
Old 07-26-2009, 06:44 PM
f150light f150light is offline
f150light is starting off with a positive reputation.
1993 ford lightning
Hello all i just purchased my 93 ford lightning and it is going to be a street/strip can. It will be 85% street. My question is I want it to run in the high 12's. I plan on using drag radials for traction. I was thinking long tube headers a cam and intake. It is a 351 by the way. What do you suggest i use to make it run 12.6 to 12.9 tHANKS
Old 07-26-2009, 06:58 PM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
Quote:
The truck when new gave high 15 sec quarter miles with high 80s MPH.
I would think that only a supercharger would get it into the 12s.
Old 07-26-2009, 07:07 PM
DJdemon6696 DJdemon6696 is offline
DJdemon6696 is starting off with a positive reputation.
AFR heads...
good cam
headers
supercharger
N.O.S
Slicks
Old 07-26-2009, 08:58 PM
redlightning93's Avatar
redlightning93 redlightning93 is offline
redlightning93 is starting off with a positive reputation.
Lots & Lots of $$$$
The more you spend the faster you go.
There is lots of help here http://www.nloc.net/vbforum/index.php
Old 07-26-2009, 09:31 PM
frankyford frankyford is offline
frankyford is starting off with a positive reputation.
There's a 93 lightning just up the road from where I live and the want $7000 for it and it's got a powerdyne supercharger on it. It is very nice condition, too bad I can't afford it right now. I would also say a good supercharger will get you close to your goal, what gear is in the rear.
Old 07-26-2009, 10:28 PM
1966Tbird's Avatar
1966Tbird 1966Tbird is offline
1966Tbird is starting off with a positive reputation.
first off you don't need forced induction to get into the 12s it is one way but you can get there with all motor as well
use the afr heads, if you are building the bottom end use the large chamber heads and pop up pistons, but if you are planning on keeping the stock bottom end get the small chamber heads as they will up the compression, do you plan on keeping it fuel injected or going to a carb? i don't know much about how to make these fuel injection systems on these trucks perform but....i do know how to build a motor with a carb, put on the small chamber large runner afr heads with a stock bottom end (low mileage that has good compression ect. ect.) and put on a good intake like an rpm airgap or equivilent port match the intake to the intake ports on the heads and port match the exhaust ports to the headers for the cam go one size bigger than what you think you'll need because you will always wonder what it would have been like with a bigger cam and that also allows some room to grow before you outgrow your cam and have to buy a new one and if you just build the motor and don't put a stall converter on your trans you will be dissapointed, i don't know what trans you have but i know with an e4od you'll want to keep fuel injection since it is all tied into your engine computer somehow, with an aod you can run as much stall as you want and still have it streetable since in third gear and in overdrive it locks out the converter unless you have a one peice input shaft (never came factory) but what ever trans you have get it so the stall is right about 100-200rpms above the advertized powerband of your camshaft that way when you launch it you will be right in the powerband, as for the gears i am sure you have an overdrive trans since i don't think you could get a 150 with a c6 or c4 and 351 so since you have overdrive you can probably run 4.56 gears with a 31in tire or so and be at about 2000-2800rpms on the highway at 60mph which is where i usually gear all of my cars to except for my truck because i would have needed 4.88s instead of 4.56s and with 4.88s i would be breaking way too much stuff, now i really doubt you'll be able to get that truck to hook with drag radials and a built motor so i would just invest in a set of slicks and have a set of street tires as well and use the same front tires for street and strip (get skinnies it really does help on the topend with friction loss compared to wide front tires)
try playing with removing the front sway bar and see how your truck likes it, i know my t-bird hooks better without the front sway bar but i also know of some cars that like the front sway bar
if that setup doesn't get you into the 12s then start to do some weight reduction such as remove the heater, smog system, air conditioning, inner door frames, inside tailgate skin, lighter rims, fiberglass front end, pull the gas tank for a fuel cell mounted in the bed. that's just the weight reduction which most of it you can make money from by selling the parts you take off and using that to fund the weight reduction parts like the fiberglass front end and fuel cell...ect remember every 10lbs saves is a tenth of a second (just rule of thumb)
if that still doesn't get you to the 12s buy a wet nitrous system (if you go carb. get a spray plate) and remember every 10hp is a tenth of a second
Old 07-26-2009, 11:25 PM
phoneman91's Avatar
Quote:
All Lightnings have 4.10 limited slips in the rear from the factory.
Old 07-27-2009, 05:59 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Supercharger.....You will need to build the rear end up, 456 gears eaton true trac , ladder or cal trac bars , after market axles , shift kit for trans , 315-60-15 MT drag radials or ET slicks , check out fast ford fiberglass , theres all kinds of ways to lighten up these trucks with out striping them , you can do it with out the SC but you will need to build the chit out of the motor.... Lew
Old 07-27-2009, 08:20 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Dont do a Powerdyne SC. They suck. Lew is right. You need a SC to keep it drivable for a 12 sec 85% street truck. Here is a combo that works for alot of lightnings for high 12 sec , Vortech SQ, Heads,5.0 roller cam, roller rockers, torque converter,full exhaust ,Nitto DR
Lightning bolt floor mat? Weston67 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-16-2014 10:27 PM
Lightning cluster in place of ours…? Rockaholic Ford Inline Six, 200, 250, 4.9L / 300 15 02-20-2012 04:20 PM
Ford Ranger with Lightning motor and 6 speed trans TREVORMERRILL2 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 15 10-12-2011 10:06 AM
ford lightning rear shock help naplesguy69 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 5 08-15-2009 03:29 AM
Lightning pvc kit Ofcrgary Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 11-09-2004 10:14 PM
Tags
1993, 50, 93, converter, f150, ford, headers, kit, lighting, lightning, longtube, makes, powerdyne, specifications, specs, stall, supercharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
