96 Ranger Clutch line disconnect - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-24-2009, 11:29 PM
Eaglefixer Eaglefixer is offline
Eaglefixer is starting off with a positive reputation.
I'm trying to disconnect it from the transmission but can't get it to come off. The plastic ring inside seems to be torn to hell and back. Can i buy just the plastic ring and can it be replaced while its connected so i can disconnect it. This is on my 96 Ranger 4.0
Old 07-25-2009, 12:36 PM
seagull369 seagull369 is offline
seagull369 is starting off with a positive reputation.
There's a little tool that's sold to get that line disconnected. I think Haynes makes mention of this in their manual. I made a homemade one by wrapping a strip of flexible plastic around the line, slid it inside the back-end of the connector, then (gently) wiggled the connector off the transmission.
On my truck, I seem to remember the retainer that actually holds the connector in place was made of metal instead of plastic as you said.
Old 07-27-2009, 07:21 PM
well i've changed my line from the master cylinder to the tranmission but i had to take the old plastic sleeve off the old line and install the new sleeve from the new line to to old and it popped right off. I have now bench bled the master cylinder and reconnected the line to the transmission and bled the slave cylinder but still having trouble getting this thing into 1st and 2nd and reverse without grinding. I guess i'll have to keep trying to bled this clutch system
Fuel Line Quick Disconnect linckeil 1987 - 1996 F150 & Larger F-Series Trucks 4 09-02-2010 09:14 AM
fuel filter - 96 Ranger - changing jb8897 Ranger & B-Series 7 07-08-2006 02:18 AM
Charcoal Canister Testing jlab Ranger & B-Series 3 10-06-2003 12:47 PM
fuel line disconnect tool pancake Garage & Workshop 16 10-05-2003 05:59 PM
how to disconnecting door chime Hotest Rod Electrical Systems/Wiring 14 02-19-2003 01:31 AM
Tags
92, 96, clutch, connector, cylinder, disconnect, ford, homemade, line, ranger, release, slave, tool, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
