Need Timing Chain Help ASAP!
Old 07-24-2009, 07:48 PM
rsdjcarter's Avatar
rsdjcarter
rsdjcarter is offline
Just got the new Timing chain from Edelbrock for my 352, the new cam sprocket is larger than the old one? Is this right? Not sure why and the guy at the Mustang shop where I bought it. Please Help.
Old 07-24-2009, 08:14 PM
mark a.'s Avatar
mark a.
mark a. is online now
No, I don't think that would be right.
Old 07-24-2009, 08:49 PM
rsdjcarter's Avatar
rsdjcarter
it's the right part number and clearances are just fine?looked everything up but can't find anything definitive.
Old 07-24-2009, 09:50 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
Bigger in which way, diameter, thickness, tooth count?
Old 07-24-2009, 09:56 PM
rsdjcarter's Avatar
rsdjcarter
Diameter is larger than the one on the truck.
Thx
Old 07-25-2009, 06:11 AM
EPNCSU2006's Avatar
EPNCSU2006
How does the tooth count compare to the original? Does the chain fit on the new sprocket? The cam sprocket should have twice as many teeth as the crank sprocket.
Old 07-25-2009, 08:37 PM
rsdjcarter's Avatar
rsdjcarter
Got it Figured out, the tooth count was 48 & 24. CS65 came over and sorted it out, totally wrong set near as we can tell it was for a FT engine. So put this one in your memory bank. Edelbrock 7808 Timing set for FE engine is totally the wrong part for your old Ford.
Old 07-25-2009, 09:23 PM
EPNCSU2006's Avatar
EPNCSU2006
Good to know! Glad you got it figured out.
Old 09-04-2009, 12:53 PM
Lvcrprts's Avatar
Lvcrprts
Lvcrprts is offline
Hmm maybe they been doing too many chebby parts and are trying to sabotage our old Fords LOL
OrangeBeast78
07-11-2011 03:20 PM
EDMist
10-28-2009 01:02 PM
MARTINT
11-06-2007 12:54 PM
Big Block Man 2
02-10-2004 02:42 PM
TheNomad
06-03-2003 04:16 PM
Quick Reply: Need Timing Chain Help ASAP!
