Mine always ran just under the halfway mark on the gauge, right around the "O" in "Normal" after I switched to a later 4.0 radiator. Before that it was a bit on high side of normal with the A/C on.
You want to be running a 195º thermostat, and hopefully your engine will operate at right around that temp, a little higher is okay but of course with a 2.9 with its very crackable heads you don't want it to get too hot.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
