Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 07-24-2009, 01:20 PM
dlmccart dlmccart is offline
Garage is empty, add now
dlmccart is starting off with a positive reputation.
2006 6.0 only idles, won't accelerate
2006 F350 6.0 turbo, no mods 84,000 miles (my first diesel). I was driving home at 65 mph and it felt like the truck died. Pulled into the ditch but truck was idling normally. When I push on the gas pedel it's like a linage poped off, no acceleratation only smooth idle at 800rpms (I seen it's a drive by wire after checking).Drove truck for 6.7 miles (3 hours) in "limp home mode" until I ran across a State Trooper that called a tow truck. I have checked this and other forums and have checked the fuses that could cause this problem. Fuse #45 is not blown so I don't think I have a wring problem in the steering colum others have spoke of. Any ideals?
  #2 (permalink)
Old 07-24-2009, 01:44 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Can you check for DTC's? Are you still under warranty? It could be your APS (Accelerator Position Sensor).
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
  #3 (permalink)
Old 07-24-2009, 02:57 PM
Benchwrench's Avatar
Benchwrench Benchwrench is offline
Benchwrench has a very good reputation on FTE.Benchwrench has a very good reputation on FTE.Benchwrench has a very good reputation on FTE.Benchwrench has a very good reputation on FTE.
sounds like you need a new gas pedal assembly. ie: what he said.
__________________
"Because Stock is not an Option".
  #4 (permalink)
Old 07-25-2009, 10:43 AM
Thanks for the input, I'll look thoses up to see how to check them. One thing I forgot to mention is I have a wrench light and engine block light on, if it makes any differents. Thanks
  #5 (permalink)
Old 07-25-2009, 11:01 AM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
Quote:
DTC 2104 forced idle dead pedal.
__________________
03/04 6.0L 350 Crew ,DRW,ZF-6, XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. Fass 95/90, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM and some other stuff.
03 6.0L Ex LTD mostly stock,05 6.0 CC srw SB, 95 f250 4x4 woods truck, 68 f100 project
Tags
2008, 2104, 350, 60, accelerate, codes, diesel, excelerate, excelerating, f250, ford, idil, idles, truck, wont, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
