Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 07-24-2009, 01:01 PM
sgettin sgettin is offline
Garage is empty, add now
sgettin is starting off with a positive reputation.
i have perhaps the dummest question ever.
but i'll ask anyway (i have no experince with this vintage truck). anywaz my truck is an 63 f250 4x4 stepside. being an ex-plow truck the bottom is basically gone so it's hard to figure out what was what (the rest of the truck from the floor boards up is i would say quite a bit above average). my question is what type front cab mounts should this truck have?. obviously the cab is currently mounted to the frame or i wouldn't be putting around the farm in it but the way it is set up now it does not have the enclosed mount with sheet metal around it and an inspection plate like i see is after market available for 65-66. so i wonder if my 63 ever had that type cab mount. the way it is now the cab is simply mounted to a factory riser or mount that comes right off the frame.
hard to explain without pictures i guess but the after market mount (looks kind of like a torque box) for a 65-66 has me confused.
thanks
  #2 (permalink)
Old 07-24-2009, 01:51 PM
camperspecial65 camperspecial65 is online now
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
The cab for your truck vs the 65 and 66 styleside trucks(smooth side) is different then yours is. Your type of cab was used on all of the non unibody/integral bodied trucks thru 1964 model year. It was also used on 65 and 66 F350 and 1966 F250 4WD and 1965 F100 and F250 4WD. The easiest way of telling is the type of instep present when you open the door...yours has a deeper curved one whereas the 65-6 2WD and 1966 F100 4WD has a straight step which is noticably narrower then yours.
As for the cab mount on the cab...the steel structure, I am not sure if its the same as the 65-6 or not but I know others on here will chime in soon enough.
This forum is the cats meow IMO for Ford truck info, and almost anything else your little heart could desire Ford truck related.
As for a dumb question...the dumbest question is one that doesnt get asked...
Welcome
- cs65
  #3 (permalink)
Old 07-24-2009, 08:56 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Front cab mounts are specific for 61 to 64 F100 and F250s and 65 F100 4x4s 65 66 F250 4x4s and all 61 to 66 F350s. They look nothing like a 65 66 mount for 2 wheel drives and the 66 F100 four wheel drive and will not fit the eariler cabs. The 61 floor is a raised floor with instep where as the 65 up floor is a dropped floor with no step.
This includes body 66 unis and body 81 conventional.
The floor mounts are reproduced by Rick at Carolina Classics along with a correct stamp drivers and passenger front floor pan.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #4 (permalink)
Old 07-24-2009, 09:02 PM
Thanks Garbz...you were the chimee I was referring too :-)
I knew they were different but wasnt sure the differences as to the mount itself...you have pics of them both offhand...if you have the early type only, I can shoot ya a pic of the later type if needed/wanted.
- cs65
  #5 (permalink)
Old 07-24-2009, 09:22 PM
garbz2's Avatar
1963 Ford F-100
Click the image to open in full size.
63 cab and mounts
Garbz
__________________
98 528I BMW
  #6 (permalink)
Old 07-25-2009, 08:33 AM
man ford company kind of switched things around a bit on that one. geez. but the mounts in the pic do look familiar and the pic will help when it comes to rebuild time on the rest of that area as well.
thanks guys for the help and information.
scott
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
