Flaring stainless brake lines
on
you can find them at Yogi's or Summit Racing has one for around 30 bucks
http://www.summitracing.com/search/D...ew=ProductName
later
John
Eastwood makes one. I bought one to do my brake lines. It is quick and does an excellent job. You produce the 45* double flares needed to connect to standard brake fittings (like master cylinder, brake hoses, etc).
Ill take a look at what eastwood has to offer, thanks. did you use stainless steel tubing because i got one of those cheapies from summit and it just pushed the tubing out the holder and then i cranked it down so tight i broke a stud. I will be using the double flare 45* because thats the flare nuts i got.
I found the Rigid was worth the money. If you are going to go with the AN 37 deg fittings, make sure you get seamless tubing. I found my tubing at McMaster-Carr.
I did use the stainless tubing from summit racing. It worked very well once I got the right tools.
Does the Rigid produce double flares? I was going to borrow one (don't remember which model) and it would only do single flares. The eastwood is expensive, but it was the only one that I could find that could handle stainless.
Thanks for the recommendations on tools, I did not realize that there was a 37 degree flare for stainless. Great stuff. I had found some1/4" seamless MIL-T-6845 304 1/8th hard stainless steel tubing and bought it for brake lines. It's designed for<style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --></style> use in high pressure hydraulic and pneumatic systems in which corrosion resistant materials are required.
I have read that 304 is not as corrosion resistant as 316, but it also doesn't work harden as easily due to it's lower nickel content. I have been bending the MIL-T-6845 304 stainless for another project and find that it forms beautifully. I'll have to get a flaring tool & see how that goes, it also polished well and it's gorgeous.
Now all I got to do is get off of my lazy rear and get the brake lines done. So many projects, so little ambition.
Best Regards To All,
Jon
Jon
