Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-23-2009, 03:08 PM
wvabeer's Avatar
wvabeer wvabeer is offline
wvabeer is new and has a neutral reputation at this point.
04 f350 clutch problem
My clutch work fine most of the time but on occation it seems to grab at a low point of clutch travel then some times it will barely engage but after i depress it again it wil work fine. has anyone else had this problem?
__________________
Kenny
04 F350 reg cab, 4X4 ,V10 ,6sp ,430 gear, 315/75/16
94 Ranger, reg. cab, Shortbed, 4.0, auto
  #2 (permalink)
Old 07-23-2009, 03:12 PM
fordf150guy fordf150guy is offline
fordf150guy is starting off with a positive reputation.
sounds like a hydraulic problem. make sure that your fluid is topped off and the air is bled out of the system. check for any leaks as well.
__________________
2004 F350 X-cab 6.0 6 speed long box
  #3 (permalink)
Old 07-23-2009, 03:52 PM
12ozd 12ozd is offline
mmmmm...beeer
12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE.
Another place to check is the plastic bushing on the end of the clutch master cylinder where it connects to the clutch pedal.
  #4 (permalink)
Old 07-23-2009, 03:58 PM
wvabeer's Avatar
Quote:
It was full of fluid
__________________
Kenny
  #5 (permalink)
Old 08-14-2009, 05:23 PM
wvabeer's Avatar
Well I have changed master and slave and I still have the problem how is the best way to bleed this beast. I followed the manufacture instructions. It seems to screw up after holding the clutch in at a few lights in traffic.
__________________
Kenny
  #6 (permalink)
Old 08-15-2009, 11:08 AM
wvabeer's Avatar
??????? Bump
__________________
Kenny
  #7 (permalink)
Old 09-22-2009, 07:04 AM
wvabeer's Avatar
Darn I surely can't be the only person with this problem.
I will try to explain it better. Usually when at a light while holding in the clutch, light turns green slowly let the clutch out and it engages at the top of the clutch and at the end after it engages you hear a burp or squeek, then when you go after second gear the clutch engages at the bottom and the pedal won't come all the way up, I have to lift it with my foot. Then the clutch will operate fine till you do this again.
PLEASE HELP!!!!!!!!!
Kenny
__________________
Kenny
  #8 (permalink)
Old 09-22-2009, 12:17 PM
mmmmm...beeer
Sounds like there is air in the system.
They can be a PITA to bleed.
A vacuum or pressure bleeder works well.
  #9 (permalink)
Old 09-23-2009, 01:29 PM
wvabeer's Avatar
I tried bleeding like the instructions said hold the slave vertical and push the plunger in and out while someone watches the level I guess I'l try to park the truck almost straight up an down and work the clutch and maybe the air will work out some how. I am open to any other suggestions
__________________
Kenny
  #10 (permalink)
Old 09-23-2009, 05:25 PM
78bigbronco's Avatar
78bigbronco 78bigbronco is offline
78bigbronco is starting off with a positive reputation.
I have heard they are a pita to bleed as well. You might be better off getting one of the vacuum bleeders like 12ozd mentioned.
__________________
09 F-350 V10 4x4 6spd CC/8' ordered 5/26/09 delivered 7/6/09
99 F-150 4x4 Reg/Short bed
78 Big Bronco 4x4 (a work in progress)
84 Tbird (351W project still in dry dock)
  #11 (permalink)
Old 09-24-2009, 07:59 AM
wvabeer's Avatar
I have a vacuum bleeder but there are no bleeder screws how would I do it?
__________________
Kenny
  #12 (permalink)
Old 11-01-2009, 08:16 PM
wvabeer's Avatar
how would I do it?
__________________
Kenny
Tags
04 , 2002 , clutch , duty , f350 , ford , problem , problems , super , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
