Mark VII 302 engines
Hi all! I own a 1994 F150 4x4 that I am fixing up, including swapping the engine. It has a 302 in it factory and I am swapping another 302 in it that I am rebuilding.
I got a 302 out of a 1987 Lincoln Mark VII and after much reading I am still VERY confused on which engine it is, the HO or non-HO. Here are some observations:
Block code is "25 E7TE CA S" and it has the E7 heads, roller lifters BUT it has the pistons without the valve reliefs just has the 2.5" diamater dish in them which I assume means they are the cast non-HO pistons, but why is it an E7 block with E7 heads, roller lifters if its not a HO?
Maybe someone could enlighten me
Thanks,
Lee
Thanks,
Lee
Ok took pistons out and measured rings, and I confirmed it has the thinner rings found in the cast pistons....so im guessing its the non-HO then. Weird thing too is it came out of a 2DR mark VII which I thought all had HO motors....and it has the 1 belt setup instead of the 2 belt setup on the non-HO...and I read somewhere that some HO motors had cast pistons....the more I read the more confusing it is
Also, did both the non-HO and HO with roller lifters have the HO/351 firing order? And the sprockets are single gear instead of double so that says non-HO too..
No, unless the 1987 200hp option was considered an HO.
Read.
http://www.thelincolnmarkviiclub.org/phpBB3/index.php
Read.
The Mark VII LSC came with the 5.0 EFI/HO engine.
The non LSC models did not. They either came with the plain jane 302 or the BMW 6 cylinder diesel.
The engine code is the 8th digit of the VIN.
From the 1980/89 Lincoln Mercury Parts Catalog / General Info Section / Page 35 / VIN Engine Codes: M = 5.0 EFI/HO 1987 Mark VII LSC only.
1988 and later: The VIN's engine code for the 5.0 EFI/HO is E ~ Both Mustang's and LSC's used this same VIN engine code.
Originally Posted by frankyford
Is there an M in your VIN number. if so you have the non HO motor.
Sorry, that's in-correct, that only pertains to 1984/86, not 1987. 1984/86: VIN engine code: M = 302 4V 5.0L CFI/HO.
IsaacJR75
01-30-2023 04:28 PM
Krisverde
08-19-2015 01:06 AM
dakota-boy
23
08-18-2011 12:42 PM
