Fuel Tank Selector Valve
As noted, the switch from AZ is not a bolt on deal, it is a universal switch. The hose hookups will not work with the factory lines, the hose ends have to come off to use it. The nipples are designed for hose, not the plastic fittings with the o-rings inside. The pigtail has to be ordered, although since the unit is universal, it is my opinion that it should be included, but... When talking to the guys at the counter, many do notrealize this is a universal switch, so buyer beware. I caught one of our guys trying to sell it like it was a factory replacement on an 88 gas truck, which uses that wonderful pressure switch mechanism. It can be made to work, but is not factory type replacement.
I would have to go look at the 83 I have sitting around to be sure, but it is very similar to a GM unit. I'll try to remember to look that up when I go in to work tomorrow. I have seen valves and pigtails on ebay pretty regularly. As stated before, it is special order, so unfortunately, I won't have one to hold in my hand...I can't come up with one online through the AZ site, but I know I can get it to come up on the system at work.
I replaced my FTSV a few months ago with one I bought from FTE/PARTS-GUY. Yes I might have paid a little more for it but I didn't have to wonder about buying the plug and figureing out the wiring. Just unhook the old FTSV and replace it with the new FTSV. Same plug and everything. Haven't had any problems since I changed it out. I'm running SVO but not from either front or rear tank. I"m using a seperate tank and keeping the two systems totally seperate so if there is a problem, I don't get stranded.
If by AZ you mean Auto Zone then the part number is (FV5C = $17.00) as I posted on page one of this post. The part is (213 Duralast Fuel Socket Assembly) but the AZ lookup number is FV5C. I know because the pigtail is right behind me sittting on the table 2 feet from me.
Anyway, you could just spend $98 and get the whole deal (pigtail included) from advanced Auto, or jcwhitney has it $82.99
I try that on the online system, and it doesn't come up. I didn't have that number with me when I was at work, so I couldn't look it up by number, but it was not coming up on Z-Net either. I will have to try again Tuesday when I go in with the number, but it really shouldn't be that much trouble to find the darn thing. It is also possible the vendor has quit making it available to Autozone for whatever the reason...
Success!!! I found the part number today in the Wells parts book (Wells makes our electrical parts) The actual usable part number is simply 213, fuel socket assembly. Lists for $17.99 I had pretty much given up, but had to find a connector that the web site claimed we had in the related parts, but was not there for a crank sensor upgrade on the Dodge Neons, and I found it in the Wells book. I got to thinking maybe I could find this in there as well, and there it was!
( Now that I look back, it was right in frontof me... thanks for making it too obvious... )
#29
on
im not finding anything via a search for FTE/PARTS-GUY.
it seems now he might be going by partsguyed or something?
is this the correct site?
www.partsguyed.com
if so,i sure dont see a 93 6 port FSV.
help lol.
i like just plugging it in and it works if the price is right.how much was it? can you post the link?
how fast was shipping?
#30
What is the price of the valve from www.partsguyed.com with shipping? I couldn't get into the catalog or find it using the search. On the plus side of the conversion, once it's converted if the valve goes again it would be much less expensive to fix.
