1.1 L Ford Industrial Engine
#31
"found three [pistons] on e bay and one at a local parts store."
Just make sure they are the same compression ratio and you should be set.
In the old Ford shop manuals it was considered acceptable to bore some cylinders different sizes from others, so if the single piston is a different bore that is okay.
Bearded Rabbit
21
05-20-2017 11:49 PM
MrFord619
09-20-2016 09:27 PM
Macrobb
48
03-05-2016 11:55 PM
