1.1 L Ford Industrial Engine
Old 08-17-2013, 11:17 AM
Beanscoot's Avatar
Beanscoot
Beanscoot is offline
"found three [pistons] on e bay and one at a local parts store."
Just make sure they are the same compression ratio and you should be set.
In the old Ford shop manuals it was considered acceptable to bore some cylinders different sizes from others, so if the single piston is a different bore that is okay.
  #32
Old 08-17-2013, 11:01 PM
skidsteer345's Avatar
skidsteer345
skidsteer345 is offline
Thumbs up
Looked at your links but all are for later 1.6L industrials and not the 70"s version of the 1.1L/1.6L industrial I have but thanks for the effort.
seattle smitty
4 Cylinder Engines
09-16-2021 12:24 AM
Bearded Rabbit
21
05-20-2017 11:49 PM
MrFord619
09-20-2016 09:27 PM
2gumby2
2015 - 2020 F150
08-25-2016 08:09 AM
Macrobb
48
03-05-2016 11:55 PM
Quick Reply: 1.1 L Ford Industrial Engine
