1.1 L Ford Industrial Engine - Page 2 - Ford Truck Enthusiasts Forums
Old 08-02-2009, 08:59 PM
luthrobediesel's Avatar
luthrobediesel luthrobediesel is offline
luthrobediesel is starting off with a positive reputation.
Havent had a chance to work on it again yet. I am almost certain it is the accelerator pump because that thing is just dribbling a little bit into the carb. You guys are very helpful thanks a lot.
Old 05-26-2011, 06:01 AM
dennishenry dennishenry is offline
dennishenry is starting off with a positive reputation.
Need help with my Jacobsen mower with the 1.1 L
Say it sounds like I have the same engine. Where did you buy your piston rings, bearings, etc.?
Quote:
Originally Posted by luthrobediesel View Post
Im working on a Jacobsen lawn mower with a ford industrial engine. Its a 4 cylinder 1.1 L carburated engine from the late 70s to early 80s. Its from a family of engines called Kent engines. A 1.6 L edition was used in the Fiesta. The only difference is the crank throw. I found parts for it by looking it up under fiesta. I put new rod and main bearings, piston rings, and had head redone. It runs great except for a couple of problems. When you ease into the hydro feed peddle, the rps decrease and when the governor tries to rev it up, it bogs down and stalls. When I try to increase the throttle too suddenly, it stalls. Im getting a timing light tomorrow an hook it up. Any idea what the base timing is? Im guessing the vacuum advance is whacked. Its been sitting for 7 years in a shop in peices because nobody could find parts. Not even jacobsen. It also overheats but I think the thermostat is stuck so tomorrow im gonna knock the guts out of it and put it back in to still slow the flow down enough to absorb the heat. Also, the governor is run off the crank pulley on the front and is mechanical. It looks like it has a place to put oil in it, im wondering if it needs some or even how to fill it properly. If anybody knows these engines, I would appreciate some input.
Old 05-31-2011, 05:10 AM
Got all the engine parts from Oreillys. Just ask for 80 something ford fiesta i think with a 1.6L. Only thing is the crank throw is different. Everything else fits good and runs good. Good luck it is a cute little engine.
Old 05-31-2011, 05:02 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
So the 1.1 has the same bore as the 1.6?
I too have a fondness for the Fiesta engines, a friend had a few of these cars about ten years ago. Very good mileage!
Old 03-06-2013, 12:07 PM
XChevyGuy XChevyGuy is offline
XChevyGuy is starting off with a positive reputation.
And 4 Years Too Late.....
NOT APPLICABLE so I DELETED MY POST.
Old 03-06-2013, 09:08 PM
An enigma
<hr style="color:#D1D1E1; background-color:#D1D1E1" size="1"> NOT APPLICABLE so I DELETED MY POST."
Rather cryptic for a first post.
Old 03-07-2013, 11:41 AM
Yeah, I not only was as I mentioned a really late addition to the thread, I realized a few hours after I posted it, not going to help anyone who might be searching the same issue. That was my original intention, to help someone who got to the end of the thread and would be frustrated that there was not a definitive solution.
We had similar problems with a Owatona Mustang 345 skid steer with the 1.1L Ford Industrial engine. Similar but not the same and not going to be relevant if someone else dug up this thread.
With Google being everyone's go-to for problems this thread comes up when searching certain issues with the difficulty of finding info on older Ford Industrials as it did for me about a year ago, it didn't help me. So when I was searching something else for using Ford Pinto parts for an industrial Ford engine, up popped this thread again. I thought hey I should add my information to this! But no.. I shouldn't have.
Quote:
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1>NOT APPLICABLE so I DELETED MY POST."
Old 08-14-2013, 06:42 PM
skidsteer345 skidsteer345 is offline
skidsteer345 is starting off with a positive reputation.
read your quote and have the same problem. (Mustang345 with a tired 1.1L)
Wondering if a get a 1.6L Festiva engine that is rebuild and change the flywheel with mine, will it work for my skidsteer.
Can't find rebuild parts for the 1.1L industrial engine but found a local 1.6L 1980 rebuild engine.
Sure hope you can help?
Old 08-15-2013, 01:58 AM
Engine swap
I believe the Festiva used a 1300 cc Mazda engine, so that is probably not going to have the same bellhousing and flywheel mount pattern as the Ford Industrial/Fiesta engine.
Old 08-15-2013, 03:57 AM
No, the 1977-80 festiva has a 1.6L engine.
Old 08-15-2013, 05:55 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
No such thing as a Festiva until 1986. It was designed by Mazda in Japan, assembled and imported from South Korea, came w/a 1.3L Mazda I-4.
1.6L (98 cid) OHV I-4: 1971/73 Pinto/Bobcat/Capri (RWD), 1978/80 Fiesta (FWD). Some of the Pinto/Bobcat/Capri parts interchange with the Fiesta, some (like the flywheel) do not interchange.
Both the Capri (1971/77) and Fiesta were imported from Germany. There was no 1978 Capri, 1979/86 Capri was a rebadged Mustang.
Fiesta didn't sell worth a hoot as no A/T or factory A/C was available. Ford dealer installed A/C was so wimpy, it couldn't blow out a match!
Old 08-17-2013, 12:51 AM
Got the wrong name... 1978-80 fiesta 1.6L engine. Hoping it is the same block as the industrial 1.6L.
Can't find oversize pistons for the Fiesta (.40 over).
Found four .30 over pistons and rings and will see if they will work.
Hard to find parts for this engine.
  #28
Old 08-17-2013, 01:33 AM
Fiesta time
Skidsteer, in your earlier post you said you found a "rebuild" engine. I thought you perhaps meant "rebuilt". But if you are looking for oversize pistons does this mean you just found a Fiest 1.6 engine that you want to rebuild?
If so, .030" overbore pistons should be fine, why do you want .040" over?
  #29
Old 08-17-2013, 10:11 AM
The 1.6L I found turned out to be a 1983 1.6L which is a different block.
Back to rebuilding my 1.1L engine.
Trying to find oversize pistons is very frustrating. They stopped manufacturing them, but found three on e bay and one at a local parts store. Hope they work..... I'll let you know.
  #30
Old 08-17-2013, 10:48 AM
tomw tomw is online now
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
If you have $2k burning a hole in your pocket, check here:
http://chicagoengines.com/industrial/
Maybe they could sell you some parts? Couldn't hurt to ask.
Or go here as they list a LOT of FoMoCo Industrial engine parts:
{I clicked on piston assembly to get this page}
http://www.adoraequipment.com/spare-...ston-Assembly/
Maybe start here:
http://www.adoraequipment.com/Spare-Parts-Catalog.php
Complete long blocks and some parts from here:
http://www.grahampowerusa.com/parts.php
Call for availability (800) 837-7070
tom
New 86 F150 owner with some problems. MrFord619 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-20-2016 10:27 PM
Need advice on booster cables 2gumby2 2015+ F150 2 08-25-2016 09:09 AM
Governor Modding - RD2-110 pump. Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 48 03-06-2016 12:55 AM
My favorite four: old Fiesta "Kent" engine. seattle smitty 4 Cylinder Engines 6 10-23-2015 03:26 PM
'81 L800 dumptruck - engine governor module dumper Large Truck 3 04-17-2014 10:31 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
11l, cart, crankshafts, engine, engines, english, ford, fuel, g1, golf, industrial, mixture, part, piston, rings, yamaha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
