Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil and Lubrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Oil and Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-26-2002, 08:28 AM
ringkong ringkong is offline
ringkong is starting off with a positive reputation.
PureOne 24651 vs.Motorcraft FL-820S
__________________
http://www.redout.org
  #2 (permalink)
Old 10-23-2002, 01:07 AM
Jakebrake Jakebrake is offline
Jakebrake is starting off with a positive reputation.
I know this was done a while back (couple of years) at
http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html
I just could not take it at face value, so I had to cut apart one of each of these filters and see for myself. Since these filters are specific to my vehicle, it left me without any doubts. Here is what I found:
1. Both filter media appear to be the same as far as color, smell, appearance, construction, but the Motorcraft filter element is slightly longer while the PureOne has a few more pleats.
2. Both backplates appear to be identical in every respect, while the silicone drainback valves are identcal except for a slight difference in color.
3. FL-820S has the bypass valve at the backplate end of the filter, while the PureOne has the bypass located at the domed (closed) end of the filter.
4. Quality of construction is very good for both filters, fit of components is very good, and both are very clean inside the filter can and everywhere else.
I have been using both filters, but mainly the FL-820S lately. From now on until I see something else to change my mind, I will stick with the Motorcraft. They are about half the price and should do as good a job, plus the bypass valve is where Ford specifies it should be. Let me know what you think.
__________________
06 F350 PSD CC/SB FX4 Lariat w/ Torqueshift, Readylift SST 2.5" Leveling Kit, Toyo 285/75-18 AT's, Edge Evolution, MagHyTec Diff and Tranny covers, Dieselsite Coolant and Tranny Filters, Rancho RS 9000XL Shocks, FS2500 Oil Bypass Filter, Magnaflow SS Exhaust
"Only when the tide goes out do you discover who's been swimming naked" - Warren Buffett
  #3 (permalink)
Old 10-23-2002, 04:25 AM
mikemc's Avatar
mikemc mikemc is offline
mikemc is starting off with a positive reputation.
Thanks for sharing. I will always buy a Motorcraft FL400S for my 3.0 because of the reasons you mentioned.
__________________
My other truck is a Pierce pumper
  #4 (permalink)
Old 10-23-2002, 05:37 AM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation
Good job of research. Thanks for sharing!
I noticed one of the comparisons you made about the filter media was by smell. I guess it must be a guy thing, because I do that too! The wife thinks sniffing things it's disgusting! But to me it helps identify some things that you are otherwise unable to compare. I confess, I smell the motor oil at oil changes. Each brand has it's own unique odor. It's probably not good for me, but I'm sure not as bad as what I breathed everyday when I worked in the oilfields.
__________________
Scott
Forum Guidelines
  #5 (permalink)
Old 10-23-2002, 09:52 AM
bodyelite bodyelite is offline
bodyelite is starting off with a positive reputation.
Post PureOne 24651 vs.Motorcraft FL-820S
Great work- near identical high-efficiency paper media with bypass valve on the right end, plus cheaper too ....stick with Motorcraft!
  #6 (permalink)
Old 10-23-2002, 10:06 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
Jake,
thanks, that was some good info. Like many others, I believe when considering price and quality, the Motorcraft is hard to beat.
Brian A
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #7 (permalink)
Old 10-23-2002, 11:13 AM
Monsta's Avatar
Monsta Monsta is offline
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
I was under the impression that Purolator MADE Motorcraft filters...
__________________
Ken
  #8 (permalink)
Old 10-23-2002, 11:21 AM
>filters...
That was the impression I had also, both from outside appearance and previous filter studies. My intention was to satisfy my own cutiosity as to what the differences between these two filters are. No doubt in my mind that Purolator made this Motorcraft filter...Ken.
__________________
  #9 (permalink)
Old 10-23-2002, 11:26 AM
Monsta's Avatar
Sit. Stay.
2005 Ford Excursion
Do you pictures for a visual comparison? Might make for a cool article!
__________________
Ken
  #10 (permalink)
Old 10-23-2002, 11:39 AM
Ran out of time last night, and right now the wife is MAKING me WORK! I can take some pictures later and put them up, when she cuts me some slack...Ken.
__________________
  #11 (permalink)
Old 10-23-2002, 12:03 PM
I'm glad you didn't take studies "as law". Many of the oil filter studies have some erroneous or outdated info. For instance, in the SHO artticle, Mobil's multipass efficiency is really based on SAE J806 test, not J1858 as stated. Another study lists Purolator's Pure One as a synthetic element, when it actually is paper media. Another lists Champion and STP filters as a thin, easily torn paper element, when in fact, it has been upgraded to a good synthetic blend media.
  #12 (permalink)
Old 10-23-2002, 12:47 PM
Like I had mentioned, the previous studies had been done a while back. With the way things change nowdays I just had to see for myself. I wish I had some money to do the Mobil1 and K&N filters. Maybe I can do that later, just to satisfy my curiosity...Ken.
__________________
  #13 (permalink)
Old 10-23-2002, 05:11 PM
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is starting off with a positive reputation.
Motorcraft 400S on my 97 4.2V6....$2.77 at Wal-Mart!
__________________
2007XL R/Cab,4.2 V6,auto
The anticipation of death is worse then death itself!
  #14 (permalink)
Old 10-23-2002, 08:43 PM
TOUGHLover TOUGHLover is offline
TOUGHLover is starting off with a positive reputation.
[updated:LAST EDITED ON 23-Oct-02 AT 08:48 PM (EST)]Motorcraft on my Ranger (and daughters "Es-quirt"), for above mentioned reasons and others - and HP - I too make use of all the senses the Good Lord 'gimme' - I "sniff" stuff, in addition to looking (thoroughly), feeling (and sorta' weighing), though I don't perform any taste tests (not yet anyway - haha ), but I have been known to give things (products) a little shake (sound\hearing) to make sure nothing internally is loose...
  #15 (permalink)
Old 10-24-2002, 12:51 PM
jim henderson jim henderson is offline
jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE.
That's great. I love it when one of us publishes results from the real world that can be of use to us.
BTW, I like to sniff the fluids in my vehicles too. The smell of the oil or coolants can tell you a lot about what is going on. Also have a strange fondness for Hoppes, WD40, Breakfree and the like. Been sniffing tranny fluid and oil for over 30 years and I don't thunk I have eny brane damage.
Jim Henderson
Tags
24651 , 42 , 820s , filter , fl , fl820s , motor , motorcraft , oil , puralator , pure , purolator , sells , v6 , whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
