R&R egr valve on 2004 F350 6.0 power stroke diesel - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-22-2009, 12:55 PM
rtorres rtorres is offline
rtorres is starting off with a positive reputation.
How do I remove and replace the egr valve on my 2004 f350 power stroke diesel ! Thanks in advance
Old 07-22-2009, 12:57 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
Welcome to the forum. Check the tech notes in the 6.0 forum, there are complete procedures.
Old 07-22-2009, 01:43 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
This pic from the 6.0 tech folder shows what I think is the best way to pull the valve:
Just take a long bar and slide it under that wire loop, lever it off of the top of the alternator and it'll pop right out.
Here's a link to the entire thread: http://www.ford-trucks.com/forums/44...r-valve-5.html
Old 07-22-2009, 10:46 PM
Steve, hey thanks thet was the most useful bit of info. I did just as the picture showed and it came right off. THANKS AGAIN
Old 07-22-2009, 10:49 PM
***** Emeritus
What did the valve look like?
Old 07-22-2009, 11:40 PM
It was completly black. Installed a new one and we "ll see if it makes a difference. What do you think?
Old 07-23-2009, 07:48 AM
***** Emeritus
If the top part of the valve was clogged up it's bound to be better than it was. If it just had a sooty coating there may not be much of a difference.
Old 07-23-2009, 11:18 AM
It was soot with a little gunk build up. I appreciate the info. This site rocks!
New member could use some help w/ EGR and Bully Dog tuner problems bullydog831 6.0L Power Stroke Diesel 12 11-29-2016 08:00 PM
EGR delete nautiqueman General Diesel Discussion 3 03-22-2016 09:43 AM
EGR replace vs. EGR delete? kyleec69 6.0L Power Stroke Diesel 15 09-19-2015 06:31 PM
Egr valve delete Shawn93 6.0L Power Stroke Diesel 3 06-17-2015 01:59 PM
2003 6.0 Power stroke diesel egr delete mod Mark Blancas 6.0L Power Stroke Diesel 11 10-01-2011 06:27 PM
Tags
2003, 2004, 2006, 60, build, deisel, diesel, egr, f250, f350, ford, location, picture, powerstroke, rr, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
