"Stop Leak" products - Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Old 12-20-2002, 10:01 AM
76_F150_390 76_F150_390 is offline
76_F150_390 is starting off with a positive reputation.
My 390 has got a slow leak at the back of the engine(intake, maybe rear main...) I don't really have time to change the seal right now. So I was thinking about TRYING one of those "stop leak" fluids in my oil.I know that it might not work, but I'll only be out a couple of dollars.
My questions are...Will this hurt my engine at all? and What do you guys think of Bar's stop leak products??
Old 12-20-2002, 10:16 AM
Border3899 Border3899 is offline
Border3899 is starting off with a positive reputation.
See my post below yours entitles Bars leak, some people recommend it some dont because it can cause further problems with clogging things up.
Old 12-20-2002, 10:17 AM
Sorry not Bars questions, it's entitles Oil Question.
Old 12-27-2002, 02:13 AM
blownbronco blownbronco is offline
blownbronco is starting off with a positive reputation.
DON'T USE IT! Or any other oil additive for that matter. I once put STP engine oil treatment in my Mercury Sable, it caused the head gaskets to blow. I'm talking 5 minutes! Good thing I just bought that car as a fixer upper!
Old 12-27-2002, 06:45 AM
jschira's Avatar
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
25 years or so ago, I put some of that "stops oil burning" stuff in my '67 Charger (young, no money for engine work). I got to tell you, it really worked pretty good. Was using 1 quart every 500 miles or so. Went a whole oil change (3000 miles) without adding oil or cleaning the plugs.
That was an old car with lots of miles on it, looser tolerances, etc.
My dear old dad warned me that I would be out of the will if he ever caught me using any stop leak product. "Plugs everything up", he always claimed. My guess is that he was speaking from experience, but he never told me the whole story.
I say if your only alternative is an engine tear down and rebuild, then it might be worth a shot to try. If the leaks are that bad, a rebuild is going to be necessary eventually. Stop leak will only buy you some time (if it works at all).
Old 12-27-2002, 09:46 AM
If you do use it make sure you do a very thourough (sp?) flush of the system before you put everything back together so you dont have further problems with the radiator.
Old 12-27-2002, 11:00 AM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
First before you put anything in your engine seal off the rear of the intake. This is hillbilly but it works. Take some carb cleaner and completely clean aal the gunk off of the rear seal area. Then take some silicone blue and glob it into and on to the crach where the rear intake seal goes. Be very genereous. Let the truck set for a day and it will stop the intake leak.. Many people mistake this kind of leak for a rear main seal leak. If you have a rear main leak use the gold eagle brand "engine sealer". It will swell the seals up instead of dumping garbage into your engine. I see no way how any engine sealer can cause head gaskets to blow.
Old 12-27-2002, 04:44 PM
What I used wasn't an engine sealer. It was an oil treatment (supposed to quiet engine make oil last longer). When I tore down the engine the stuff I used was gummed up on the oil pan. It was stuck on the cylinder walls. It looked like peanut butter. This caused my engine to overheat which is what blew the head gasket!!!
Old 12-28-2002, 03:10 AM
BigMattXXL's Avatar
BigMattXXL BigMattXXL is offline
BigMattXXL is starting off with a positive reputation.
Why don't you throw some 10-30 Valvoline MaxLife in there? It might help. Probably can't hurt, either.
Good luck!
XXL
Old 12-28-2002, 04:36 PM
Man, I junked that car a while ago!!!
Old 12-28-2002, 10:26 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Post "Stop Leak" products
Stopping an oil leak Boss08v10 1987 - 1996 F150 & Larger F-Series Trucks 5 01-07-2013 06:05 PM
REAL MAIN SEAL REPAIR STOP LEAK robjs111 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 10-02-2011 11:28 AM
Bars Rad stop leak, bad or good idea?` mibson Ranger & B-Series 19 11-15-2009 05:58 AM
Rislone TexasGuy001 Oil & Lubrication 11 08-03-2007 10:15 PM
Radiator Stop Leak??? MemorexKid 1997 - 2003 F150 3 02-15-2004 10:35 AM
Tags
390, bars, ci, engine, ford, leak, leaks, oil, product, products, rear, seal, stop, stp, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
