04 5.4 no factory knock sensors installed?
Old 07-21-2009, 12:09 PM
Reno348's Avatar
Reno348
Reno348 is offline
Hey Guy's, I pulled a po325 code so I purchased one of 2 knock sensors and got a location printout from Ford. It shows them behind the fan pully under the intake.So I removed the airfilter,housing over the intake,altinator and the coolent deal under the altinator, and to my surprise I found the (2) treded screw holes ( bank one and bank two) but no knock sensors had been factory installed. Is this a normal occurance?
Thanks, John
Old 07-21-2009, 12:58 PM
Twinsdad98's Avatar
Twinsdad98
Twinsdad98 is offline
Were the threaded screw holes open or plugged? I would have thought that if the engine was missing knock sensors you would have had codes all along. Are there pig tails there for knock sensors? Not sure what the P0235 code is, but I'm guessing that our engines may not have a knock sensor. If you purchased this vehicle used, maybe previous owner had work done and shop never re-installed them.
Old 07-21-2009, 12:59 PM
Flash1034's Avatar
Flash1034
Flash1034 is offline
Its hard to believe the factory wouldnt have installed knock sensors in this day and age...?
Flash
Old 07-21-2009, 01:20 PM
Reno348's Avatar
Reno348
Reno348 is offline
Truck has 120,000 miles Iv owned since new. Cam phazwers at 28k under warrenty is the only work done on truck. Code po325 is knock sensor code.Two tredded holes only ,no markings from previos attachment. I called ford and thay said that halfway threw production thay may have desided not to put them in. ???. All manuals show sensors.
John
Old 07-21-2009, 01:40 PM
Flash1034's Avatar
Flash1034
John
Oh..I see its a 2004 like mine. Hmmmm?
Flash
Old 07-22-2009, 10:18 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
The sensors are further back on the block. You have to take the intake off to see them. there are 2 of them. Most common cause of failure I have seen is the wire harness is routed outside of the IMRC rods whenever someone works on it. The wires are supposed to come between the intake and IMRC rods but it's harder to connect them like that.
Old 07-24-2009, 12:14 PM
mainman's Avatar
mainman
mainman is offline
could one of you explain what a knock sensor is im just curious
Old 07-24-2009, 04:28 PM
shorebird's Avatar
shorebird
shorebird is offline
Shettlera
Modular V8 (4.6L, 5.4L)
05-11-2017 06:20 PM
Viperfoxbat
01-26-2017 05:56 AM
Max Williamson
1999 to 2016 Super Duty
12-21-2016 06:12 AM
POLARISrider500
02-04-2016 05:52 AM
coppertales
08-30-2015 09:28 PM
Quick Reply: 04 5.4 no factory knock sensors installed?
