04 5.4 no factory knock sensors installed? - Ford Truck Enthusiasts Forums
Old 07-21-2009, 01:09 PM
Reno348 Reno348 is offline
Reno348 is starting off with a positive reputation.
Hey Guy's, I pulled a po325 code so I purchased one of 2 knock sensors and got a location printout from Ford. It shows them behind the fan pully under the intake.So I removed the airfilter,housing over the intake,altinator and the coolent deal under the altinator, and to my surprise I found the (2) treded screw holes ( bank one and bank two) but no knock sensors had been factory installed. Is this a normal occurance?
Thanks, John
Old 07-21-2009, 01:58 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
Were the threaded screw holes open or plugged? I would have thought that if the engine was missing knock sensors you would have had codes all along. Are there pig tails there for knock sensors? Not sure what the P0235 code is, but I'm guessing that our engines may not have a knock sensor. If you purchased this vehicle used, maybe previous owner had work done and shop never re-installed them.
Old 07-21-2009, 01:59 PM
Flash1034 Flash1034 is offline
Flash1034 is starting off with a positive reputation.
Its hard to believe the factory wouldnt have installed knock sensors in this day and age...?
Flash
Old 07-21-2009, 02:20 PM
Truck has 120,000 miles Iv owned since new. Cam phazwers at 28k under warrenty is the only work done on truck. Code po325 is knock sensor code.Two tredded holes only ,no markings from previos attachment. I called ford and thay said that halfway threw production thay may have desided not to put them in. ???. All manuals show sensors.
John
Old 07-21-2009, 02:40 PM
Quote:
John
Oh..I see its a 2004 like mine. Hmmmm?
Flash
Old 07-22-2009, 11:18 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
The sensors are further back on the block. You have to take the intake off to see them. there are 2 of them. Most common cause of failure I have seen is the wire harness is routed outside of the IMRC rods whenever someone works on it. The wires are supposed to come between the intake and IMRC rods but it's harder to connect them like that.
Old 07-24-2009, 01:14 PM
mainman mainman is offline
mainman is starting off with a positive reputation.
could one of you explain what a knock sensor is im just curious
Old 07-24-2009, 05:28 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
04 f350 cluster problem need some help Max Williamson 1999 to 2016 Super Duty 2 12-21-2016 07:12 AM
high output alternator /3 batteries Brian Davis 1999 to 2016 Super Duty 5 04-05-2015 10:38 PM
Knock Sensor Replacement FordRick Expedition & Navigator 4 08-03-2013 01:46 PM
WACKEY TACHey mattb77 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-13-2011 03:02 PM
F-250 volteer fire truck needing some help. 10 speed 1999 to 2016 Super Duty 5 12-26-2009 01:58 PM
Tags
2004, 2006, 3v, 54, code, f150, ford, intake, knock, location, motor, po325, sensor, triton, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
