Throttle Body / Acclerator Linkage Cover - Ford Truck Enthusiasts Forums
Old 07-21-2009, 04:37 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I am looking for a new black plastic cover that sits on top of the throttle body.
The part number is E9TA-9E766-AA.
I have tried to look it up on FTE Parts Guy and Direct Ford Parts. It comes back with no results found.
Does anyone know where I can get this or is it obsolete?
Old 07-21-2009, 09:39 AM
frankyford frankyford is offline
frankyford is starting off with a positive reputation.
This may sound crazy, but have you tried craigslist? Maybe someone is parting a 95 out and may have one. By the way, if you look in my gallery you'll see that me and you have the exact same truck except yours looks better. Also, try the classifieds in the paper. Matter of fact, I'll check with my neighbor, he's got a 92 F-150 with the 6 in it that he's not using, but I'm not sure that one will fit yours or not.
Old 07-21-2009, 09:42 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
junkyard.
Old 07-21-2009, 09:51 AM
Quote:
I haven't seen you on the forum in a while? I remember your truck with the cooper cobras on it. It looks great. I hardly ever see trucks with our paint scheme and color.
Its got to be one for 5.0 or 5.8. I was hoping to find a new one that wasn't all scuffed up etc.
Old 07-21-2009, 10:01 AM
Yeah, I've been on the road, trying to move some freight. I've been asking alot of questions on my truck about the problems it's having. Changed all the sensors out only to find out it's the PCM that's bad. Just ordered a new one
Old 07-21-2009, 10:17 AM
How much was your PCM? Is your transmission code U for 4R70W? If so then we have exactly the same truck.
Old 07-21-2009, 10:46 AM
The PCM was 215 at O'reilly's auto, they price matched autozone. My PCM part no., if it' the same as your is F4TF-12A650-BBC and say's Bug2 at the top. The internet say's it came from a 95 Bronco. My trans code is either an S, N, or A. it's a 14 bolt pattern, but the 4R70W is the same shape only slightly larger than the AOD/AOT trans. I don't think my rear gear is 3.55, it feels more like a 3.08. The tag is off the pumpkin and I don't have a tach on it or I could tell buy the RPM's. I just really hope it's not a 2.73 which I doubt would be in it, but would explain the great fuel econmy I've been getting.
Old 07-21-2009, 10:51 AM
Hey, just thought of something, but may require a little polishing. If you were to get an old cover you could sand it down and smooth it out and put some high temp black paint on it. Just a thought
Old 07-21-2009, 10:55 AM
quicklook2's Avatar
they are plastic and can usually be cleaned.
Old 07-21-2009, 01:35 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
I may have one at the house, let me look tonite and I'll get back to ya. What happened to yours?
Old 07-21-2009, 02:09 PM
quicklook2's Avatar
first thing i take off.
i have a whole box full of different ones.
Old 07-22-2009, 06:29 AM
I doubt you have 2.73 gears. I think it was only in the light duty 5 speed trucks.
What kind of fuel economy are you getting? I get about 17-18 mix.
My truck originally came with 3.08.
If you want a tach just find a cluster from a 94 95 and swap it in. Its plug and play. I actually have a 94 Lightning cluster in mine.
Old 07-22-2009, 06:31 AM
Quote:
It looks bad and took it off to clean it up and then put it back on and it cracked.
Old 07-22-2009, 07:45 AM
Yeah, believe it or not I'm getting around 19 mpg before the PCM went out. I try to keep my foot out of it, but get on it when I need to. I'll have to look into the tach cluster. You know as well as I do at 65-70mph there's only about a 400 rpm difference between the 3.55 and the 2.73 and I think it's only 300rpm difference with a 3.08. The take off is a whole different story. Which as soon as the funds come available I'm planning on putting in 3.55".
Old 07-22-2009, 09:54 AM
How many miles on your odometer? Mine has 270,000.
I'm hoping that after the exhaust leak is fixed I'll be able to get 19.
If you swap to 3.55 gears get a LS traction lock too. Its so much better than one wheel wonder.
How do I find proper Ford part numbers? AVR2 Escape & Escape Hybrid 2 12-24-2015 08:07 AM
THROTTLE BODY VACUUM PORT onanymonday S. California Chapter 4 03-29-2015 12:08 PM
1998 3.0L throttle body dpmetzler Ranger & B-Series 6 11-20-2013 02:10 PM
Throttle Body Fuel Injection workingdog FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 02-22-2006 03:57 PM
Would this be a good setup for my 302? nitemandick Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 19 04-08-2003 12:38 AM
Tags
2004, 54l, 9e766, body, bolt, cover, e9ta9e766aa, explorer, f150, fits, ford, linkage, plastic, taurus, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
