Forward odo meter to 0.000
Old 07-20-2009, 02:53 PM
DJdemon6696's Avatar
DJdemon6696
DJdemon6696 is offline
the odo meter has about 90.000 miles on it now.. i wanna forward it to 100.000
so marking 0.000 on the meter.. how do you forward one??
Old 07-20-2009, 02:57 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Well there are ways to do it but it's not legal. But on a truck that old take the speedo out. Slide the silver pin that holds all the numbers in place out .Turn all the digits to zero and re-insert pin.
Old 07-20-2009, 03:00 PM
DJdemon6696
hmm.. im doing it becuase im putting a new engine and new everything so its like having a new truck to me.. to start the engine count at 0.0 back
oh and btw thanks
Old 07-20-2009, 03:01 PM
lew52's Avatar
lew52
lew52 is offline
???? Drive it another 10.000 miles or so then it will read 100.001 & so on .. I don't know how to make it 0.000 ..can it be done ... Lew
Old 07-20-2009, 03:03 PM
ford390gashog
It is as easy as I mentioned above.
Old 07-20-2009, 03:24 PM
lew52's Avatar
lew52
lew52 is offline
Ok thats cool , i don't know much about the 89 speedos , so i learned something here, thanks ... Lew
Old 07-20-2009, 03:33 PM
BucksTrucks's Avatar
BucksTrucks
BucksTrucks is offline
Mine is 10 miles from being 00,000!!! 200k there I come
Old 07-20-2009, 04:51 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
oh and btw thanks
that is against the law.
you are welcome.
Old 07-20-2009, 05:15 PM
Louie3's Avatar
Louie3
Louie3 is offline
I think as long as you dont sell it and keep it for ever you should be fine, not a 100% positive lol
Old 07-20-2009, 07:04 PM
DJdemon6696
i did it.. its a bit complicated but its possible.. you have to take apart the whole thing.. the gears that holds the turning things with the numbers on it.. and put it at 0.000 and carefully set it together back..
Old 07-20-2009, 07:48 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
Usually when people tamper with an odometer, they roll the mileage backwards
Old 07-20-2009, 08:53 PM
donnor's Avatar
donnor
donnor is offline
odo woes...
I would also like to "roll mine forward": My 1995 F350, upon reaching 399,999.9, rolled not to 400,000.0 but back to 300,000.0. I drove, fueled, insured, licensed, and serviced this truck for 100,000 miles of which I now feel robbed! It seems that these LCD odometers were not programmed to display any digit above 3 in the leftmost position. Perhaps there is a tech savvy person here in FTE Land that could offer a "workaround" for this condition? Based on previous research here and elsewhere I know there are others in the same situation.
dn.
Old 07-21-2009, 02:08 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
dn.
Are you kidding me!! That sucks!!
Old 07-21-2009, 03:52 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I don't think tampering with an odometer on an older vehicle is illegal.
I think it is something like 15 years or something.
What about when you install a different instrument cluster to replace a damaged one?
Also, I have a new instrument cluster in my 65 Mustang now that reads about 1200 miles. I figure since the car is mostly restored and has that many miles on the new drivetrain it is correct.
Old 07-21-2009, 05:04 AM
EPNCSU2006's Avatar
EPNCSU2006
http://www.carfax.com/car_buying/odometer.cfx
http://www.odometertampering.com/
If the instrument cluster is changed or the mileage is not accurate for the vehicle, you'll have to sign a mileage disclosure statement when the vehicle is sold or the title is transferred. I just looked at the title for my truck and there isn't a vehicle age limit on the mileage disclosure statement.
At the end of the day, do what you want, but know that changing mileage readings is illegal, and if you ever sell the vehicle, you'll have to disclose the alteration. There is also a check-box for when the odometer is above its mechanical limits, as in the case of the odometer that won't go past 399999.9 miles.
Quick Reply: Forward odo meter to 0.000
