88' tank selector valve - Ford Truck Enthusiasts Forums
Old 07-20-2009, 09:09 AM
99BlueOval 99BlueOval is offline
99BlueOval is starting off with a positive reputation.
I've got good pressure from both tanks, but nothing coming out of the selector valve.
Is anyone having any luck finding a replacement for the tank selector valve? Aftermarket from Advance/Autozone appear to be electrical and wrong. Local dealer says +$150. And FordPartsNetwork is gone.
Old 07-20-2009, 11:31 AM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Lightbulb
Try PM'ing Numberdummy (Bill), and be specific about the application....
If it's available through the dealer network he can likely find it for you at the best price.
Ed Olsen is another that posts here on FTE. You might ask him too.
EDIT: I tried a quick search....
http://www.ford-trucks.com/forums/63...1988-f150.html
http://www.ford-trucks.com/forums/67...-question.html
Old 07-20-2009, 11:37 AM
keiser blade keiser blade is offline
keiser blade is starting off with a positive reputation.
Smile
i had the same problem, i took it off the truck, and unscrewed the bottom, where it looks like a filter, its actually a reserve (i learned that from here) their are 2 valves in the bottom with o rings on them, one of my valves were completely stuck, and o rings were bad. So i pulled and pulled on the one valve with a straight pick it would hardly move, so i used an air compresspor and a air blower attachment, then i found which port went to the stuck one, and blocked off the output side, the air blower got the valve moving enough to get some penetrating oil in it. it worked great after that. Then i replaced the o rings, kinda tricky, the valves will fall down into the body, so i used the air blower and got the main one back out, just as if i was blowing in the port to free it up. Then on the other one it wall fall down into the body completely, so hold the tank selector like it would be bolted to the truck, get the right side of the valve pointing down, and use the air blower again, catch the valves with the straight pic and put the new o rings on. i thought i was done when the valves fell down in their but i decided to use the air and it will blow them back out, just have them lined up right. It woll probably take you several times to get the valves right and the o rings back on, but it will work.
you will need a helper to do this or i did at least
hope it helps
later brandon
Old 07-20-2009, 11:44 AM
yea all the ones i found were wrong, so i just decided to tear into it , knowing worst case scenario was like $170 dealer only, i was just gonna bypass it for now if i couldnt get it to work, cause i dont have a lot of funds to go by the wayside
if u need anything just pm me ill help ya the best i can
later
Brandon
Old 07-20-2009, 12:28 PM
Well, I broke one of the ports on the resievor.
So I need a new one and have had no luck.
Old 07-20-2009, 12:32 PM
Trying to sell it!
I'm trying to sell the truck & it knows it. I havent had to do much this past year, until I decided to sell it. Within a month or so I've a computer bite the dust & now the valve..
Brandon, what did you do to connect the lines?
Old 07-20-2009, 01:53 PM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
Sounds like your local dealer is charging you list price.
If this is the fuel tank selector valve for a gas engine, the valve should sell for around $73.00 from the dealer.
http://www.ford-trucks.com/forums/76...tor-valve.html
Old 07-20-2009, 03:29 PM
Yup
Yup, thats it. I tried browsing under fuel supply & fuel induction.. also searched by part number, no luck. I would love to find one online in the $70's... All my local dealers want to keep themselves in business just on my sale.
Anyone have any luck recently with an online supplier?
........backed out to the home page & searched by part number. I found what I was looking for..
Old 07-20-2009, 04:41 PM
$88 shipped, hope its the right part!
Fuel tank selector valve newportman WTB - Parts & other 4 12-25-2011 01:47 PM
Tank Selector Valve 88 250 1987 - 1996 F150 & Larger F-Series Trucks 1 10-06-2010 08:17 PM
fuel tank selector valve plumbing 410 Highboy 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-13-2010 09:03 PM
Fuel Tank Selector Valve JCastellaw 1966 - 1977 Early Broncos 7 08-16-2008 09:58 AM
tank selector or check valve? hotrodford_88 1987 - 1996 F150 & Larger F-Series Trucks 5 11-19-2000 08:41 PM
Tags
88, ford, selector, tank, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
